Question about Gateway M305CRV Notebook
What causes that?
So i took out the battery and unplugged the AC power.. then plugged back in the AC and it booted fine... i am curious to what causes that?? In case i run into it again or is there something more i need to fix??
  • ranjitme May 11, 2010
    Can you please be bit more specifc
  • 408 Answers
Sounds like the power jack is loose and the connection is bad.Nove the tip around while its plugged and see by your indicator light if it goes off and on
Posted on Jul 28, 2009
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Oct 09, 2012 | HP Compaq 2510p Notebook PC
Toshiba l670d is not booting.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
hope this helps
Sep 22, 2012 | Toshiba Satellite L670DST2N01 Laptop
No power from battery to laptop
are you installing it with correct polarity
is one of the battery terminals in the laptop damaged so that it is not making contact
May 22, 2017 | Acer Computers & Internet
Computer will not turn on. Battery is fully charged.
this is how i did one the other day and it booted right up, do not turn your laptop on, remove the battery and do not have your ac adapter plugged up to the computer, after you have took the battery out and unplugged the power cord, hold the power button down for 10 seconds, this releases all internal power from the motherboard, after this step is completed do not put your battery back in, plug your ac adapter up to your computer and push the power button and it should boot up. The Hp DV series computers have a recall on alot of the batteries, so you might want to look that up on the HP website.
Nov 07, 2010 | HP Pavilion dv6000z Notebook
Power problems with a Compaq Presario C700
Sounds to me like a broken connector on the socket on the motherboard.check, ,or a broken wire at the plug end, check, or the like, or the battery is not making contact as you discovered. Meter the PSU, and wiggle the plug, and socket and see if it makes and breaks connections.
Mar 07, 2010 | HP Compaq Presario C700T
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
Gateway M305CRV Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
