Question about HP PSC 1401 All-In-One Printer
Printer loads multiple pages
My HP 1401 all in one's document feeder loads multiple pages instead of single sheets.
    Problem Solver:
  • 4 Answers
You may be using a cheap (thin) paper weight. Try a thicker gauge paper. Could be dirt or dust in the feeder track. Try vacumming it out and try again.
Posted on Dec 12, 2008
How i can scan multiple pages in one file ??
You need a document feeder. The printer has on or it doesn't. If it does you usually place the documents face up in the overhead feeder and the scan sensor in the printer will detect a load of paper in the feeder and choose to there instead of a single sheet under the glass.
Apr 17, 2016 | Artronix Technology Artec ViewStation AS6E...
HP Laserjet 3050 all in one
pls clean printer solenoid it wl solve
Nov 27, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Lost my manual and don't know how to send a fax. Not sure which tray the document goes in. Can you help?
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
Jul 11, 2011 | HP Officejet 5610 All-In-One InkJet...
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Nov 21, 2008 | HP LaserJet 3380 All-In-One Printer
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Aug 05, 2008 | Office Equipment & Supplies
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
HP PSC 1401 All-In-One Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
