Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Problem with hearing sound when I connect Sonytrv33e camcorder to my computer with USB
Hi I have a problem with hearing sound when I connect Sony trv33e camcorder to my computer with USB I am using image mixer software and a few weeks ago it was all fine now I tried today and I can see the image on the computer screen but no sound - really frustrating Hellllllppppp????
Make sure that the sound capture device setting is on USB audio.  In image mixer - click on the USB icon onthe left of the screen and then click on the wrench icon in the upper right corner of the screen.  That will bring up another window.   In this window check to be sure that the sound capture device setting is USB audio.
Posted on Oct 15, 2007
SOURCE:
Hi HRU? Sir pls tell me how I can copy my Movies from Cam Coder of Sony DCR-HC28E in my pc although I have connect via usb cable to my computer but no any reply i foud. So pls guide me how I can?
This is the step-by-step for downloading from your camera as found on Sony's tutorial page:
  1. Turn on the computer.
  2. On the computer, install the USB driver for the digital camcorder. Note: Only the USB driver included on the supplied CDROM will properly enable the digital camcorder for USB streaming. Alternatively, you can download the USB driver here.
  3. Turn on the digital camcorder to the VTR, VCR or PLAYBACK mode.
  4. Turn on the USB streaming feature of the digital camcorder.
  5. Connect the USB cable to the digital camcorder.
  6. Connect the other end of the USB cable to the computer.
  7. Cue the video to the beginning of the video footage to be transferred.
  8. Start the video capture software on the computer.
  9. Begin playing the recorded video in the camcorder.
  10. Begin importing the recorded video with the capture software.
Dec 16, 2010 | Sony DCR-HC28E Camcorder
I need a usb cable to connect my sony handycam model#ccd-trv138 to my computer
CCD-TRV138 is analog camcorder that can not be connected directly with computer by usb cable, this camcorder does not have any usb port to hook it to computer.
Only digital camcorder/ camera can be connected with computer.
Hope these info will help you.
Thanks.
Nov 06, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Dcr-pc9e handy cam with no connectors
To transfer video from your camcorder to your computer you will need a firewire cable (IEEE 1394). Only with this cable you will be able to transfer video.
Please note that you will also need a firewire port on your computer. if you don't have one then you can buy a firewire PCI card.
Please see the following link for more info and pictures.
http://en.wikipedia.org/wiki/IEEE_1394_interface
Regards,
nicolasiac
Mar 25, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
My mac won't connect with my dcr-sr47camcorder
Follow the steps below to troubleshoot if the computer does not recognize the USB connection from the camcorder.
  1. Turn off the camcorder.
  2. Ensure the USB cable is connected securely to the camcorder.
  3. Ensure the other end of the USB cable is connected securely to the USB port on the computer. NOTE: Connection through a USB hub is not supported.
  4. With the exception of the mouse, keyboard, and camcorder, remove any other USB connected devices from the computer.
  5. Turn on the camcorder.
  6. On the camcorder LCD screen, touch the computer or hard disk icon.
  7. If the issue is still not resolved, connect the USB cable to a different USB port on the computer.
  8. If the issue is still not resolved, try uninstalling and reinstalling the USB driver.
  9. If the issue is still not resolved, test the USB port on the computer by connecting a different USB device.
  • If the other USB device operates, the USB cable may need replaced or the camcorder may require service.
  • If the other USB device does not operate, then the issue is being caused by the computer. If the computer is connected to a network, try disconnecting it from the network or connect the camera to a computer that is not on a network. In addition, mapped drives may cause connection issues; drive designations D, E, or F must be available. It may be necessary to contact your system administrator or computer manufacturer.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C455202
Jun 19, 2009 | Sony Video Cameras
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
I rty to connect my DCR-HC18E to the computor via usb but it doesn't work
What Windows (XP or Vista) your are running in PC?
Is there any error message comes when you connect Sony DCR-HC18E with PC?
Does PC sounds Ding when you connect camera at USB port?
Reply on above will help me to provide you assistance.
Oct 27, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
No sound after capture on computer
Can you tell my from the menu on the camera how you connected it to your computer?
Apr 02, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Problem connecting
you have to buy this:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040741&tab=Features
Dec 01, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
