Question about LG Televison & Video
Our LG takes a while to turn on....is there someway to fix this?
It's almost like it has to "warm up" to turn on. It did not do this when we first got it. It's about 4 years old. It works fine once it turns on, but it can take up to 5 minutes sometimes.
    Genius:
  • LG Master
  • 2,432 Answers
Replace bulging capacitor at power supply board the it will resume to normal operation.
Posted on Jul 22, 2012
SOURCE:
  • 41 Answers
SOURCE: Model is the LG LDC 47
Your Power Board is going bad.Try to get it repaired under warranty.
Posted on Mar 13, 2010
rulds2008
  • 3866 Answers
SOURCE: television will go blank after a few minutes
sounds like you got a bad back light or invertert, Take a flash light to the screen and see if you see a faded or distorted picture if so replace the back light and or
inverter. A local tv repair shop would be ideal if you do not know how to test these things.
Thanks hope this was very helpful to you when you cast your ratings and feedback today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 04, 2010
caroldon
  • 17130 Answers
SOURCE: LG 42PG20-UA 42" Plasma.
You have a given a good account of the fault as the fault seems central to weakness of electrolytic capacitors in the board.
Please check the link below for some tips ;
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Now it is important that you must find the spot where the heat is necessary to identify the rough area of fault. So open the set when cold and in the first place use a good light to look out for any capacitors that are bulged or leaked. If so you need to replace after cleaning the area of leak.make sure that the board is also looking good with the soldering joints or you can use a touch up soldering of all dry joints/suspected joints.
Finally heat the area near the power, the driver section and the processor section one at a time noticing when the set powers ON very easily. If you have a freeze-it spray the fault can be easily confirmed. Spray on the suspected section to cool so as the fault will surface up.
A bit of patience is the most important tool as you might need to proceed carefully till the suspected component is identified. Once the area is fixed you can use the soldering iron to heat the component to confirm. Some of the semiconductors/IC can also cause this issue but the possibility of electrolytic capacitors going weak is high.
Hope this helps
Posted on Jan 18, 2011
  • 679 Answers
SOURCE: I have the exact same issue as the unsolved
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Posted on Feb 12, 2011
nadeemnazar
  • 300 Answers
SOURCE: when i turn the tv
problem with your display it going to be dead
Posted on Apr 26, 2011
Heat TEMP and blower problem.
Your blend doors are not working properly. There is small electric motors that move them. Shouldn't be really expensive to have fixed.
Jun 01, 2017 | 2000 Chrysler LHS
I just turned my digital receiver on & my LG tv & the tv says it's not programmed
Try to unplug from power both the set and the box for several minutes and then power both back up---this will allow both to try to reboot.
Dec 08, 2012 | LG 32LG30 32 in. LCD HDTV
1994 buick roadmaster temp light keeps turning on & off, but car isn't overheating, what can it be? What's your problem?
Usually a sign of a problem with the temp sensor or the wiring harness back to the computer.
Oct 13, 2012 | Buick Roadmaster Cars & Trucks
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 23, 2011 | Washing Machines
New Lg 42" plasma flatscreen
How new is it? Usually these TVs have a cool-down period, but a warm up of longer than 15 seconds is unusual. I would return it or try to get it fixed under warranty.
Mar 08, 2011 | LG Televison & Video
Televison & Video Logo
53 people viewed this question
Ekse
