Question about Acer V223WBD Monitor
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to instease sound from the monitor speakers. Is it possible to use external speakers, and how would I go about connecting them, by passing the monitor. I'm not really computer literature, so be extra discreptive.
    Master:
  • 461 Answers
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Posted on Dec 13, 2008
How do you hook up sound from surface rt to acer monitor 2014
To connect anything to the speakers on your acer monitor you need to use an audio patch cable that has 1/8 inch or mini headphone jacks on each end. Like this one.
5mm Male to Male Stereo Audio Cable...
You connect one end to the headphone jack on your Surface RT and the other to the audio in jack on the monitor. Make sure the power is on for the monitor and that the volume on both is a third or half way up and you should be able to hear the sound.
This is for the monitors user manual.
Acer AL1715 User Manual Amazon com C2G Cables to Go 27413 3
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Volume too low
are you using the monitor's volume or are you using speakers? If its monitor volume, I would say go into the main menu of the monitor by pressing the menu button. Then go to the volume setting and raise the level. If the volume level is already on the highest, you may want to consider using another solution to monitor sound, such as speakers or headphones connected to your computer.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
How do I adjust the volume on ASUS 19
if the volume is too low and your monitor cant be raised more, youll have to use another form of audio. Try headphones or speakers. Monitor speakers are cheap and unreliable so often they dont get loud enough for people's needs.
I just bought an X223W LCD monitor for my computer and there's no sound. My previous audio cable has no place to plug into this monitor. How am I supposed to get sound?
Your previous monitor had built-in speakers. The Aces LCD monitor do not have built-in speakers, therefore you need to purchase external speakers and plug these into your computer.
Nov 18, 2010 | Acer 22" X223w LCD Monitor
Cannot make speakers work
You need to use audio cable with ministereo phone plug at both ends of the cable, then one end is plugged into the monitor audio line in jack (usually Green color), another end of the cable will be plugged into the audio line out (Green color) of the PC. Set the volume level to about 1/2 way at first and then adjust the volume control panel (Master volume and WAVE level, these two controls affect the sound output feeding the monitor) on the PC.
You can try feeding the monitor with MP3 player first to make sure the monitor speakers are working properly first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Acer B223W 22 inch LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
No sound
Yes, you do. You need an stereo audio cable. It will have a connector like found on portable headphones on each end.There should be a recepticle for it on your monitor, usually marked light green. This cable would then connect to your computer's audio output. Although, I don't think your monitor has speakers.
Apr 10, 2009 | Acer 22" X223w LCD Monitor
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Dec 12, 2008 | Acer V223WBD Monitor
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
How to turn volume up on my LG flatron monitor??????????
there dont have speakers yo, so you need a separete adio
Oct 27, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
See all Acer V223WBD Monitor Questions
Acer V223WBD  Monitor Logo
249 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
