Question about Acer V223WBD Monitor
Acer V223w monitor
Sound is very poor, but picture is great. Can I use external speakers? How would I go about making that connection, understanding please, that I am not computer literate.
    Problem Solver:
  • 7 Answers
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Posted on Dec 12, 2008
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
Acer v223w on and off
You could have a faulty power supply. If the capacitors have a blown (deformed top) then they are faulty. Replacing these capacitors with new ones may fix the problem provided nothing else is faulty. Make sure you replace them with the same voltage and capacitor rating.
Nov 30, 2012 | Acer V223W LCD Monitor
I can't get any sound since, I changed to an Acer flat screen monitor. What could it be?
check your cables at the back of the pc . Sounds like maybe a cable from the sound connection "generally pink" got pulled out partially when changing out the monitor. The monitor should have nothing to do with the pc's sound.
If the monitor is one with built in speakers make sure that the cable is going to the external out from the sound card. Hope that helps...
Feb 23, 2011 | Acer Computers & Internet
Desktop is larger then the screen....!!!
Change the resolution, if you dont know how, just google it
Jul 19, 2010 | Acer V223W Monitor
I have a V223W monitor it goes to a black screen
Possibly cold solder joint or a cable needs resitting will need to take to trained technician as covers will have to come off to reflow pcb boards
Jan 04, 2010 | Acer Computers & Internet
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Dec 12, 2008 | Acer V223WBD Monitor
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
Acer Aspire 5630 - Low speaker volume, poor quality, OS=Vista
It's likely that the speakers are blown out if it's quiet and making a crackling sound. To fix that, the speakers can be replaced or you can use external speakers.
Mar 23, 2008 | Acer Aspire 5630 Notebook
Acer V223WBD  Monitor Logo
569 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
