Question about Meade ETX-125AT (500 x 138mm) Telescope
Changing the coordinates of the autostar for meade etx 125
After moving to a new home, I tried to change the coordinates the autostar uses in aligning my telescope. I followed the instructions in the manual, but it no longer finds anything.
  • 67 Answers
Use the postal code entry to change your location.
menu-->select item-->setup-->site-->add-->select option 1 for postal code-->enter your new postal code-->site-->select-->your postal code-->select item-->setup-->align
Posted on Dec 13, 2008
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
Meade ETX-60 Horizontal drive
The AZ worm gear is not engaging the gears. There is a spring next to the gear which applies pressure -- open up the base and see if the spring is loose or broken.
May 23, 2010 | Meade ETX-60 AT Telescope
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
Oct 08, 2009 | Meade Optics
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
ETX-125 Autostar controller not working
I assume the small red light on the power panel is ON. ???
If it is the scope is receiving power--- check to make sure the cable from the hand controller is plugged in properly-- jiggle the cable to see if you have a loose BAD cable. Before you panic --- try another cable or reverse the ends ---
Before you buy another hand controller try a new cable-- scopestuff.com sells a nice long flexible one for the 497 hand controller.
Jan 14, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Dec 12, 2008 | Meade ETX-125PE (500 x 127mm) Telescope
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Trouble shooting
my Meade ETX-125 makes a grinding noise when I try to slew to the left and will not move. Any suggestions will be appreciated. Bill
Aug 30, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Meade ETX-125AT (500 x 138mm) Telescope Logo
162 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
