Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Router wpn824 stops working green lights all come on and hold
Works for a while then stops working and green lights 1-4 come on and stay on constant reset and it works again but then repeats problem
  • 30 Answers
Hi there, if all the light come on and you only have one or no ethernet/lan cables connected then there is a fault with the router i`m afraid and you need to replace or return it assuming its still under warranty... sorry
Posted on Dec 13, 2008
Hi, I have two problems: 1- My controller disconnects when I hold or press X repeatedly. 2- My play & charge kit light turns green after a few seconds when I want to charge the controller's...
Both issues might be to the same problem.
First problem number 1... you should try using some AA batteries and try to see if you still get the disconnect issue when pressing the X button repeatedly. If so then you have either a bad controller or you have some interference with your controller and other device that might be messing with the 2.4Ghz radio frequency. (Note: that sometimes metal frames and some wires can also bleed signals.)
If your controller works fine with the AA batteries then the issue is likely your rechargeable battery.
Secondly problem number 2... I have had similar issues with batteries. often times it is just because you have reached your limit with your charging on your battery. If you are an avid gamer then this might be the issue. You might want to try the tweak to getting your charger to work again:
"First insert the play and charge kit a little way in just enough to make a contact but not enough to click into place - light goes red - when light goes green slide it out a bit so the green light on the play and charge kit goes out - The green light on the controller should stay on, count to 2 in you head then slide it back in again like before. As soon as the light goes green to tell you its charged slide it back out again I had to do this 3 - 4 times then as if by magic the light should just stay red and carried on charging."
Hope this helps.
Aug 01, 2011 | Microsoft Xbox 360 Wireless Controller
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
I have conon mx 868 but i have got error message 6502 and 150 how can i solve the problem?
Here are instructions:
The MPTool is designed for service works with the printer Canon MP-Series
when in Low-Level mode. This is NOT the same as "service mode"
Currently supported for
MP150, MP160, MP170, MP180, MP450, MP460. MP150, MP160, MP170, MP180, MP450, MP460.
BEFORE activating MPTool...you need to
To activate LOW LEVEL mode:
1. Unplug the power cord to the printer for a moment.
2. Then, hold down the on/off button while plugging in the power cord. Keep holding the on/off button down.
3. Right away the green power light (in the button) will turn on solid. Keep holding the on/off button down.
4. Press and release the Stop/Reset button.
(the button w a red triangle in a red circle)
5. Now you can release the on/off putton.
The green power light will go off and the yellow Alarm light will stay on.
Now you can run MPTOOL and resetting the ink counters will work.
Your printer will show up as "another" Cannon printer.
When you finish you must again unplug the power cord for a moment and then just plug it back in. After you do this, you'll see both printers listed in Printers (controll panel) and one will show as offline. You can then rename this offline printer as "Low Mode Canon"
or whatever works for you so you don't mix it up with other functions.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
For
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Reset manual "Ink Absorber Full"
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again
Canon MPC INKTank FULL
button pressing
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Apr 08, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Error E22 in my MP145
Error E22 = Carriage error
to reset this error follow the steps below--
with the printer powered off but connected to a power source , you must:
1. Press stop/reset button, and then press [ON/OFF] button to restart
2. Press [ON/OFF] again and then press twice the stop/reset button.
3. Press [ON/OFF] & Stop/reset button together, this time to enter the repair status and power lights will be green,
4. Press stop/reset button 4x and warning lights will be go out in [ON/OFF]button.
5. Turn off the printer.( it must be turn off) and then turn it on again.
Use with your own risk ,
i’ll try this way and my Pixma MP145 not blink again.
The number of the Reset button pressing
5 Unplug cable power. (for MP145 / MP150)
6 Turn Off Power. (for MP160)
Note if the above steps did not work's means you need to check your Carriage;
Hope this helps...
Good Luck!!!
Mar 23, 2009 | Coby Audio Players & Recorders
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.(it must be turn off)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
110 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
