Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43FDX01B rear projection TV
I have a convergence problem. When you try to adjust the convergence the green line ( which is not adjustable) is not straight. The bottom half of the line is straight but above the center line it jogs to the right until it gets to the top then it jogs back to the vertical center.
  • 1,284 Answers
It is adjustable only in the technician menu. You will most likely need to replace the convergence IC's in the TV. This is a very common issue. The locations are IK04 & IK05 and are generic part numbers STK392-110's.
Posted on Mar 10, 2007
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair, for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Red and green waves...double vision 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Nov 05, 2009 | Hitachi 43FDX01B TV
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 43fdx01b rear proj. hdtv
if you are using Y, Pb,Pr, connection to the tv from a sat or cable box check the red wire on both ends red may be disconected.
Feb 09, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B Green Line Not Alligned
If you slap the set on the side and the colors shift and dont line up, it is most likely that one of your convergence IC's has cracked solder joints. It is also possible that the IC has burned out. The convergence IC's will have to be resoldered and possibly replaced, and that should be done by someone with experience in repairing and realigning convergence circuits in projection TV's.
Aug 19, 2007 | Hitachi 43FDX01B TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
118 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
