Question about Meade ETX-125PE (500 x 127mm) Telescope
Changing the coordinates of the autostar for meade etx 125
Tried to change the zip code for the autostar locater of my ETX 125. it now no longer finds anything.
  • 67 Answers
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Posted on Dec 18, 2008
The vertical lock knob on my Meade ETX-70AT was over tightened and is broken. I contacted Meade and was told that they no longer stock this part. Looking for a source for the part.
You might be able to drill a hole through the plastic knob and use a washer and a bolt to hold the screw tight. Or do something like this fix:
Mar 21, 2011 | Zhumell Meade ETX-70AT Astro Telescope...
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
Ik wil graag een Nederlandse handleiding voor de Meade ETX 90
Meade has all of their ENGLISH language manuals on this web site.
Here is your telescope- ETX90
A dealer in the Nederland may have one in your language. Locate a nearby telescope shop.
Apr 27, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
I have a Meade ETX model M telescope. I need to
Meade "might" sell you the replacement part. But most likely they will want you to return the scope for repairs.
Call them:
Feb 10, 2010 | Meade ETX-105PE Astro Telescope Premier...
Meade ETX 70 telescope won't turn on regardless of power source
Dead on arrival!
Meade can fix these, but they must be shipped back to the factory.
Here is their customer service web site:
Aug 17, 2009 | Meade Optics
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Need instruction manual for 1996 or 1997 etx 90 basic model
The manuals are all available to download from
If your scope has the motor drives and a control panel into which a controller could be plugged, then you just need to buy an Autostar 497 - always available on eBay for about £85. However, there are older models of the ETX which only have one motor or as a spotting scope for terrrestrial use with no motors - Autostar cannot be connected to these.
Look at the pictures of scopes on eBay which come with Autostar - if your looks like these, Autostar will fit. Else you are out of luck!
Apr 11, 2009 | Meade ETX-90 (48x90 mm)
use the postal code entry to change your location.
menu-->select item-->setup-->site-->add-->select option 1 for postal code-->enter your new postal code-->site-->select-->your postal code-->select item-->setup-->align
Dec 12, 2008 | Meade ETX-125AT (500 x 138mm) Telescope
Trouble shooting
my Meade ETX-125 makes a grinding noise when I try to slew to the left and will not move. Any suggestions will be appreciated. Bill
Aug 30, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Meade ETX-125PE (500 x 127mm) Telescope Logo
221 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
