Question about GE Profile Harmony DPGT750EC Electric Dryer
How do I get to the drum to check the belt
I have a General Electric profile prodigy dryer, the drum turns, but it is making a loud grinding type noice, I can't get it open to see drum where does it open at? Do you have any ideas of what is causing it? Thank you Doc
  • Anonymous Dec 15, 2008
    HOW DO I GET TO THE BELT ON MY DRYER DRUM. I HAVE THE SAME PROBLEM. MY DRYER WILL NOT SPIN BUT THE HEAT IS WORKING JUST FINE. THANKS FOR WHATEVER ASSISTANCE I CAN GET. MY e-mail address is brownsugar621943@yahoo.com
    Mary in distress.
    Scholar:
  • 111 Answers
Doc,
It sounds like you have either a worn out rear drum bearing and or front drum slides. Has the problem gotten worse over the last few months of use?
Mary,
It is impossible for your dryer to produce heat without the drum turning becaue there is a "belt switch" that will prevent the heater or gas valve to power up if the belt breaks. One exception is if your dryer is very old and doesn't have the belt switch on it. It would then have to be circa 1982 or older before UL required all dryers to have a belt switch. One exception to this would be two fold- Your heating element would have to be shorted against the steel heater frame AND the belt broken at the same time. Very unlikely for these two things to happen at the same time. 30 years expierence talking... Brian
Posted on Dec 16, 2008
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
Drum turns but makes a banging and metal grinding sound
The felt bearing on the front of the drum is worn out. Immediately stop running the dryer, and replace the plastic drum inserts and put in a new felt bearing before machine damage happens (if it hasn't already). While there, grease the rear bearing and the idler pulley bearing. Check the belt too. Good luck.
Nov 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Loud dryer noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfhgf
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
77 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
