Question about Dell Latitude D600 Notebook
Dell latitude d600 series setup
I cant get my dell laptop to get past the boot option, i need to know what settings to use like the boot order,boot configuration,basic device configuration. if anyone can help it would be really nice
    Master:
  • 474 Answers
I can help, Leave everything to me!!!!
Im asuming its doing what is called, " The windows boot loop" or as we call it at work anyways.
Dels are known for this.
let me guess, it starts up normally, gets to the windows startup but asks you to pick between 4 different start up options like safe mode.
Do you have your original CD that came with it, or at least a windows XP CD?
You will need one.
What you do is,
1st: Bot from CD. Start the machine with the Winxp CD in the drive, hit F12 for boot options, or whatever key function it is. Do this as soon as you turn it on,
2: select " Boot from CD" and press any key when it askes if you want to boot from CD.
3: It will load like your doing a fresh install of windows. Thats alright, its normal and no it wont re-install windows at this point.
4: Once it loads, it will have some options. Press " R" for repair.
It will go out and to the command prompt after about 5 seconds.
5: Once at the command prompt, type in exactly ( CHKDSK C: /P ) Dont include the ( ) . Then press "Enter key "
6: after it runs the disk check, normally about 3 to 5 minutes, It will finish and go back to C:/
Just type ( EXIT ), Enter key, and let it reboot.
you can remove the disk now or later, shouldnt matter, It will go to the options screen like before, but just let it default to the normal startup, or hit enter.
Windows should now load fine and you shouldnt get that message at startup anymore.
WHY THIS HAPPENED?, you may be asking.
For some reason, certain Dell Hardware and software conflict, usually when you have installed some new program, or for just no reason.
Your Boot Up files get corrupt or cleared and windows needs those to start.
What you did was re-installed those windows files.
Now copy and paste into a word document and print it out in case it happens again. Not likley but it could.
This works with any computer experienceing this issue, usually, unless there is something worse going on.
You can help others now that you know how and become a hero, make sure to charge them $10 though for your time:)
Let me know if this doesnt work and we can try something else.
Good Luck.
Posted on Dec 12, 2008
  • Dell Master
  • 4,806 Answers
Ok, go into the bios (press F2 on boot) then you can change the boot order to the hard drive, save the settings and exit the bios, the computer will reboot and should load up the OS
kind regards and please don't forget to rate us
Tell me how to enable dell latitude d600 setup password
go to setup when booting usually del key or f key in bios you will see security section you can add passwords for booting and to enter windows
Feb 02, 2011 | Dell Latitude D600 Notebook
Whenever I start my dell latitude d600 it says " No boot able devices- strike F1 to retry boot, F2 to setup utility". what should i do? please help.
It is telling you it cannot see the hard drive anymore. The drive has probably died. you really have only two options replace the hard drive or replace the whole laptop. Hopefully you had your data backed up. Sorry for the bad news, but good luck.
Nov 26, 2010 | Dell Latitude D600 Notebook
My dell d600 display invalid configuration please run setup it repeat the same message even when I press f2
Download trinity restore iso and boot your laptop using a cd. I think it'll have similar repair options and one of them may do the trick.
Aug 28, 2010 | Dell Latitude D600 Notebook
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
May 20, 2010 | Dell Latitude D600 Notebook
I have a Dell Latitude D600 and it comes up with a message "unmountable boot volume" can you please help me? Thanks, April
hey... the problem is most probably due to missing boot.ini file... to set it right, insert the windows disc in the drive, boot from it... in the setup select recovary console... repair the windows... it should solve the problem...
cheers...
Apr 04, 2010 | Dell Latitude D600 Notebook
Latitude D600, how use FN key to have the numeric pad on
In the system setup (F2 at boot) look for Numlock settings, there should be an option to change the key combination for numlock
Mar 31, 2009 | Dell Latitude D600 Notebook
Dell Latitude 60 Laptop Won't Load windows
You can either press F8 repeatedly at boot or the Delete key for setup to change the boot drive to cd with the Windows cd. F12 will get you a one time boot option as well. Steve
Jan 26, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 won't go past the Dell startup screen
Tap the f7 or f8 key, when you turn it on, it should go into safe mode, Go into start programs, accesories, tools, and restore, select restore, select a date closest to today and let it go through the restore pocess, if it suceeds and starts up, rub a good virus program right away, it sounds like you picked up a virus or trojen, just be patient and it shoul be ok, if it won't go into safe mode, let me know, that will require more work. And before you do anything, unplug, remove the battery for a few minutes and replace, try it and if it still won't run, do the above, thanks ,GYM
Dec 19, 2008 | Dell Latitude D600 Notebook
Dell D600 latitude laptop infra-red device
I don't know about that buttry to make sure it is enabled in the setup of the pc.
"press F2 WHEN BOOTING UP AND GO TO THE SECTION OF THE SETUP WHERE THE IR DEVICES IS"
Nov 10, 2008 | Dell Latitude D600 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
1,676 people viewed this question
Alun Cox
