Acer speaker? Have V223W 22'' monitor. Have the sound button om computer up, but speakers very soft and hardly heard. Previous 17'' Westing house was super. Love the picture on this, but need more sound
  • cricket1423 Dec 14, 2008
    You are a genius. I thought I looked on the monitor, and it took me a few tries to find and increase the volume. IT WORKS GREAT! Thank you so much. Now I'm ordering another one just like this for the office.
I have Benq T201W LSD monitor, but i can't turn on it's volume.....i have checked  everything.......what can i do??
Posted on Jun 25, 2010
    Problem Solver:
  • 7 Answers
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Posted on Dec 12, 2008
Acer V223W off center
it happened to me. I changed computers but that did not solve the problem so it's not the video card. what did help was I turned off the monitor to reboot it then, using a different computer I reset the resolution to the lowest possible setting. when the monitor adjusted to the new resolution it reset itself. I then set it back to the higher resolution and everything was centered again.
Mar 12, 2013 | Acer V223W 22 inch Monitor
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
New G215HL monitor connected to HP Compaq Presario harddrive - no sound. Previous monitor had a sound port, this one does not.
You need to connect an external set of speakers to the Audio output of the harddrive, as you put it. At the rear, or some other convenient place you should find a set of at least three, "Jacks" locate the "Green" output Jack, and use that to feed the powered speakers, you then will be able to hear sounds....
Sep 28, 2011 | Acer 22" X223w LCD Monitor
Connected my acer AL 1717 monitor to my computer but unable to activate the sound from monitor speakers?
You have to plug the monitor speakers in. The sound output from your sound card is green, and you connect a small cable between that port and the input on your monitor.
Feb 18, 2011 | Acer AL1717 17" LCD Monitor
I just bought an X223W LCD monitor for my computer and there's no sound. My previous audio cable has no place to plug into this monitor. How am I supposed to get sound?
Your previous monitor had built-in speakers. The Aces LCD monitor do not have built-in speakers, therefore you need to purchase external speakers and plug these into your computer.
Nov 18, 2010 | Acer 22" X223w LCD Monitor
I cannot get the sound to work. There is a cord for the monitor that I THINK is for the sound but there is no reciprocal port on the hard drive.
Acer X223W does not have built-in speakers. There are three ports on the back: 1 AC input port, 2 video input ports (DVI and VGA).
Mar 28, 2010 | Acer 22" X223w LCD Monitor
Speakers
HI
Even when speakers are built in you sometimes have to plug the speaker (out) port on your PC to the speaker (IN) port on the monitor. This requires a cable that doesn't usually come with the monitor. Hope this helps.
Jun 20, 2009 | Acer 22" X223w LCD Monitor
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Dec 12, 2008 | Acer V223WBD Monitor
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Computers & Internet Logo
686 people viewed this question
David Payne
David Payne
