Question about Alpine MRP-M350 Car Audio Amplifier
My sub quit working
I have a kenwood head unit, a 300 watt alpine amp, and a 10 inch boston fused subwoofer. i got in my car and my sub wasnt working. I checked the fuses in my sub and they were fine. Then i checked the fuses in my amp and they were both melted. i replaced them and i still have no sub. What has happened and why and do i need to take it in and have it fixed?
  • 3 Answers
First off you should have installed an inline fuse block that fuse will pop first an inline fuse is cheap go to a wall=mart it will run you around 10.00 that gets mounted under your hood cut your power cable in half the one part of the cable should be cut 12 inches that will tie into your possitive terminal on your battery after that is all tightened to your battery you will strip about an inch of coating offf of your power wire tie that into the end of your fuse block make sure it is tight than do the same to the other side just measure from there to your mounting spot for your amplifier and tie your power cable into your amplifier use 8 gauge power and ground cable... your problem with your amp is that you burned up a couple capasitors or even a resistor i just fixed an amp that both fuses were smoked just tear your amp apart look under the control board you will see were a sauder joint is cracked those capasitors and resisters are very cheap there made out of ceramic i just got done repairing my friends amp works like a new one.. good luck if you have problems or w you get it fixed email me.. gordo8785@yahoo.com best of luck buddy..
Posted on Jan 10, 2009
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Blown subwoofers
Does the amp have an input 'clipping' LED? The worst thing for a speaker is to try and reproduce an unclean signal. Just make sure not to overdrive the amps input. You might also purchase higher rms rated speakers. As far as the ground is concerned, paint and/or oil, rust etc have been cleared from contact area, correct? Seems like if ground were insuffecient, power to amp would drop out.
Nov 03, 2009 | Kenwood KFC-W2512 Car Speaker
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Alpine in dash tv issue
this is the problem with the additional battery wiring. use appropriate cutout and do rewiring. make sure the Dynamo has the enough capacity to charge both the batteries. better avoid using your music system till the problem is rectified.
Aug 08, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I would like to upgrade the speakers of my ford 6006cdc Can anybody give suggestions on this thanks
kicker or rockford for subs. hifonics, power acoustics, kenwood for amps. pioneer or alpine for cd deck.
Jul 19, 2009 | Car Audio & Video
I have a set of Alpine Type R 12 inch subs... I have a 1500 watt amp powering them but when I turn the music up, the bass cuts out. Where should I start looking for the problem?
ground is loose(most likely amp), battery running low, subs might be damaged? feel free to keep me in touch if problem occurs more after checking grounds and power source and subs. Also might need to re-tune your head unit and amp?
Jul 03, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
Is Sub Underrated for my Amp?
fuses wont restrict the current flow the amp is way too much for that sub. it may not have damaged that sub yet but it will. you might only need a 100 watts rms too run it.but you will need sowe where about 2000 watt sub too run off that amp
Dec 28, 2008 | Pioneer TS-SWX310 Car Subwoofer
Subwoofer blew up my car stereo
You didn't mention an amplifier. Did you try to connect your subwoofers directly to your head unit? If so, that is why you no longer have a working head unit, unfortunately. You have to have an external amplifier to drive those subwoofer, not 22 watts per channel from an in dash stereo. You're correct in your assessment that putting the subs in again would cause the same thing. Find a reputable shop that can sell you and properly install the equipment you need to get you up and running again. Sorry for your loss.
Jun 27, 2017 | Car Audio & Video
Alpine MRP-M350 Car Audio Amplifier Logo
390 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
