Question about Kenmore 24032\24036 Top Load Washer
My wash will not spin fast enough to get all the water out
I get a code of ol 1 min. before it finishes and it unlocks the door.
I open the door and the cloths still have water. I have to push the
rinse dran and spin to get all the water out after each cycle
can anybody help me?
  • luzram812 Jan 09, 2009
    my washer is an
    Kenmore elite Oasis HE top loader
    Type:580 Mod:110.708263
    When I start a wash load it stop with 34min. remaining. it does not spin water out. it then starts adding water. the washer never changes to say rinse.it just added more water with very little agitation.and it goes from 34min to 4min. left and it start to drain water with very little spinning.then it stops at 1min left. it will spin the water out if I push rinse and drain and stop 2nd rinse so it will only drain and spin. I did have a repairman check it and he said the pump was fine and that I just needed to keep doing what I am doing now. the only thing is I don't think its rinsing my cloths.
  • 113 Answers
A model # would be helpful, but sounds like you have a clogged pump. Send me the model and Ill let u know for sure. Dave www.washermd.com
Posted on Dec 16, 2008
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
Oct 18, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
Hi I have a Kenmore 110.27087601 model cti360000 The washer does not go in to an agitate mode. For a regular wash it will add water and spin 3 times. Then it fills with a large amount of water while...
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&%#@
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How do you unlock fh code on duet washer-wife forgot to turn on water & washer locked out-now door won't open & can't clear code by just pushing reset or unplugging-not sure how to maually...
Switch machine off for approx. 10 min. then with water open, try and select a short wash cycle and let it finish. Also push the door firmly in before you retry because you have been trying before to open it.(latch might not be correctly closed).
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
102 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
