Question about Conair MN250CS Hair Trimmer
I have tried everything and it still doesnt trim what am idoing w
Doesnt trim properly it just pulls
  • rockysistyni Dec 13, 2008
    still have no response
    Problem Solver:
  • 7 Answers
If it is pulling instead of trimming, you may need to oil your blades (they're sticking). there should have been a tube of oil in your package. run just a small amount of oil along blades and turn on to let the oil get worked in. do this regularly but don't over oil them, it gets messy.
Posted on Feb 16, 2009
Ido not know if the key is programmed but every thing in the car works radio ,blower works
True, everything will work when the key fits and will turn it all on, but won't crank the engine for start. The key is not the one with the proper code to make the connection so you'll have to get a locksmith to make you one and program it for the code in the switch head. Only way my friend.
Nov 26, 2017 | Cars & Trucks
How do I tighten my Weiser front door handle
Depends on the model. Usually there are 2 screws behind the trim plate that you need to tighten. The handle may need to be removed, to take off the trim plate so you can get at the screws. If that's the case the handle will have a small pin on the shaft someplace. Push the pin in and pull the handle off. Then carefully pry the trim plate off, tighten the screws and reinstall everything.
Feb 09, 2015 | Refrigerators
How to remove seat ibiza 2001 door panel as window won't close properly and grinding
door panels are held on by screws in the arm rests , winders ,door handles and around the outside by push in plugs under the trim. There is a flat bladed tool that you insert between the trim and the door and twist and this pulls the plugs out of the door. When everything is disconnected (with the window down ) lift the whole door panel up of the top of the door.
Jul 14, 2014 | 2000 Seat Ibiza
I have a 97 Jeep Grand Cherokee Laredo. The liftgate has always had issues. Used to open only when it felt like it. Now doesn't open at all. They handle doesnt seem to be connected or is broken? Any help?...
Try pressing and holding in the plastic trim piece at the bottom, right below the liftgate handle, while at the same time pulling on the handle. It should open. I had a GC that gave me the same problem opening.
Apr 16, 2011 | Jeep Grand Cherokee Cars & Trucks
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
98 durango- how to replace the headlight switch, there are two screws, where are they located? Thanks
you have to pull the dash trim plates off then everything will be very simple from there ,usually the trim is just held in with push clips tilt the steering wheel down and gently pull the trim away from the dash sometimes you have to pull the transmission lever down too for the extra room needed to remove the trim,just remember to put your foot on the brake and then back in park once the trim comes away,ps there might be screws in strange places in the ashtray under the pull out cup holders just look as you pull
Apr 15, 2010 | 1998 Dodge Durango
I have a Nokia 5800, cant connect ido bc3100 headset
Got it. Press VOLUME +, VOLUME -, and POWER ON, and the blue light turns on, still. then search for it with the phone.
Oct 27, 2009 | Cell Phones
I am installing a new radio/CD deck in 1995 tacoma.
To access the trim cover screws, you first have to remove the knobs on the fan control levers. Then, with a key or flat bladed screw driver, pull the plastic cover out. The screws are behind this plastic cover.
Dec 29, 2008 | 1995 Toyota Tacoma
Pontiac montana heater works but doesnt blow heat out on defrost
If the heater core is good and the blower works, the valve doors may not be opening and closing properly to direct air towards the proper vents. This may be because something has fallen in and is obstructing their movement. The actuating motors may not work properly, or the linkages that connect them to the mode doors may be worn or improperly adjusted. You can get a look at the mechanisms by removing the driver side knee bolster (two screws) and a lower trim panel on the side of the center console.
Be careful fiddling with the linkages. Everything is plastic and easy to break, and replacing the heater box requires removing most of the dash.
Dec 20, 2008 | 2001 Pontiac Montana
Conair MN250CS Hair Trimmer Logo
136 people viewed this question
Top Conair Health & Beauty Experts
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
