Model bm20x Is this brush supposed to rotate? If so, it will not rotate and when plugged in it only stays on (the on/off switch doesn't work-must unplug the machine to turn off) It sounds like something is flying around in there, like a small piece of plastic. Can i fix this myself? How can I open the machine to look inside? I don't want to break it more.
SOURCE: On Kenmore Whispertone, model 116
Turn the power nozzle over again, press the handle release and lower the handle to the floor.
Then flip the switch cover upwards and remove the switch.Click this link below to get complete instructions and diagrams:---
http://technoanswers.blogspot.com/2011/06/how-to-remove-switch-from-handel-on.html
this should help.thanks.Helpmech.
SOURCE: Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: My washing machine (model LSB6300LWO)
It sounds like perhaps the motor coupler is broken..it is something that wears out and the 2 blankets didnt necessarly cause it but was the final end of a already worn part...it is pretty easy to replace the coupler and this youtube video will show ya step by step how to replace it.
The part number for it is 285753A your local appliance parts store would have one or it could be ordered online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
here is the link to that video http://www.youtube.com/watch?v=9K1KHEogf3c
GENE..OldTech2332
SOURCE: Kenmore 70 Series Dryer won't
heatman101
SOURCE: Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
