Question about Dell Axim X5 Pocket PC
Dell Axim PDA backup battery
Older PDA, cant find where the backup battery is, but a message comes on that it is low. If it is behind the battery, is there a way of removing battery and not losing program?
    Problem Solver:
  • 4 Answers
There is a small wafer type battery inside the case. Similar to a CMOS battery in a PC. You need to replace it. You can do it yourself if you have the right tools, i.e. tork drivers. Battery is around $4.00 .
Posted on Dec 13, 2008
Dell Axim X5 Backup battery
CR2032 battery. Backup your information first.
Jan 03, 2010 | Dell Axim X5 Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
Aug 06, 2009 | Dell Axim X50v Pocket PC
AXIM X3 Language
1. Download Axim X3 English (A01) setup, link from here --> http://www.slipstreamsolutions.co.uk...dates.htm#Dell
2. run the setup and make a backup ROM of youre x3, save someplace handy. I now have a file named A01-10240300GE.RIS
3. Run setup again, try to upgrade, get an error message - wrong language, etc but in that DELL folder, you now have a file named, in my case, P16R_A04080402EN.IMG
4. Open with a hex editor A01-10240300GE.RIS and copy all lines from 00 to 07
5. Open with a hex editor P16R_A04080402EN.IMG, select all lines from 00 to 07 and paste there the 7 lines from the first file, save with any name WITH .ris EXTENTION!
6. Run setup again, choose backup/restore and point to the modified .ris file. Now you have the same thing in that window, up and down side.
Do like a normal backup, DO NOT TOUCH THE PDA, THE PROCESS CAN TAKE UP TO 12 MINUTES!
The PDA restarts itself and, voila, you have axim x3 with a new language.
Jul 28, 2009 | Dell Axim X3 Pocket PC
Backup battery discharging
hi thanks for using fixya!
You have to bring your Dell Axim X5 PPC to a service center, to check further the back up battery if needs to change it.
If you need further assistance, let me know.
May 28, 2009 | Dell Axim X5 Pocket PC
I'm getting a message - backup battery very low etc -
you can buy a Backup battery for the axim X3 series on Ebay for about 17.00 that includes shipping. best price Ive seen
Dec 05, 2008 | Dell Axim X3 Pocket PC
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Good Eevening :
You could get original disk from ebay at times but all you need is the Activesync that can be downloaded from Microsoft. Get Active sync 4.2. The newer ones do NOT work with the X5.
Good luck with the wireless card. The Axim does not play well with many of them. (sometimes works but mostly not) Try drivers from d Link and be sure to remove the old drivers first.
Dec 02, 2007 | Dell Axim X5 Pocket PC
PDA will not turn on
If it isn't completely broken, I would recommend a few things:
1.hold down the power button, and push reset. It will ask you if you want to wipe the contents of your device. Push the button to cancel.
2.Pull the main battery and the backup battery. This will wipe everything on your device but it may get it up and running again.
Apr 03, 2007 | Dell Axim X5 Pocket PC
Dell axim x5 back-up battery
It is a knows issue for the backup battery not to take charge once they reache 0%. The backup battery is a pretty crappy NiCD cell. As the job it is supposed to do is pretty important I recomand to have it changed. For most PDA's this is a standard 3V battery. You should have your pda dissasembled and either have the battery manually charged (to see if the PDA can handle it later) or simply have it changed. This shouldn't be an expensive repair. For more info, feel free to reply. Good luck.
Feb 16, 2007 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
231 people viewed this question
Alun Cox
