Question about Cameras
Usb device not recognized
Canon digital camera
    Genius:
  • 1,199 Answers
Your going to have to download the drivers and software to the computer you are useing! go to www.canon.com do download if you do not have cds
This should fix ya!
Posted on Dec 12, 2008
Unable to download pictures
In the short term you can take the memory card out and use a card reader - at least that will let you see the pictures.
Mar 21, 2010 | Canon PowerShot A85 Digital Camera
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
USB DEVICE NOT RECOGNIZED
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 23, 2009 | Canon PowerShot G10 Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't download to my pc from my canon powershot A720 IS
Have you installed your camera software?(driver) If you have try a different USB port.
Aug 15, 2008 | Canon PowerShot A70 Digital Camera
Canon PowerShot A75 Digital
02 possibilities
  1. there might be a problem with your computer check in the system properties, device manager, usb. if all the usb drivers are properly installed the attach the camera.
  2. After connecting the camera switch it on from the top of the camera.
Regards,
Manoj Joseph
+91 9352008418
Jun 14, 2008 | Canon PowerShot A75 Digital Camera
Windows XP doesn't recognize my new Canon SD1100 camera even after loading software as instructed.
It is very simple you guys! I had the same problem with my Windows XP SP3 and SOLVE IT EASY!
1. Unplug all your USB devices. If you have hubs, unplug only the devices attached to the hub, not the hub from the computer.
2. Open the registry and delete the following 6 branches.
H_L_M\System\ControlSet001\Enum\USB
H_L_M\System\ControlSet001\Enum\USBPRINT
H_L_M\System\ControlSet001\Enum\USBSTOR
H_L_M\System\ControlSet002\Enum\USB
H_L_M\System\ControlSet002\Enum\USBPRINT
H_L_M\System\ControlSet002\Enum\USBSTOR
3. Restart your computer and attach one by one your USB devices. If you have hubs, first let the OS to recognize your hubs, then attach the USB devices.
Your Digital Camera should be recognized immediately by the system. If you don't have your Digital Camera software installed you can use Windows Scanner and Camera Wizard to upload your photos.
Cheers from Guvidu Romania
Apr 09, 2008 | Canon Cameras
Cameras Logo
425 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
