Question about Gateway M305CRV Notebook
Gateway 305crv won't power on and was fine 5 minutes ago
I was adding software and downloading a few things. I packed it up and hard powered it off and brought it over to a friends house. When I got here i plugged it in and tried to power it up and it would not power up at all. I see the light in the front showing it has life but it won't turn on. i didn't drop it or abuse it in anyway. i was about to send it to my bf in the military so he'd have more stuff to do in his off time. Now i do not know what i am going to do to fix this issue. It has a new battery and new power inverter for the screen.. i did pull it apart but everything looks like it is in place.. any suggestions to how i can test it or get it back up?
  • 3 more comments
  • endestria Dec 12, 2008
    I tried both suggestions with no luck.
    So beyond that what might it be? There isn't much of anything i need off it i just need it to work.. hehe. I just wiped it and started over with it.
    IT WORKED!!! But what causes it to do that?? I took out the battery and the AC power for 5 minutes then just plugged in the AC tried to boot and it worked.. weird.. what maks it do that?
  • debig Feb 09, 2009
    I too have a Gateway m305crv. The on/off button has stopped functioning. The power supply is working. What should I do?
  • steve234 Feb 17, 2009
    I have a 305crv that will power up but then shut off and starts all over again. and just keeps doing this. Know any way to solve this. thanks Steve
  • Gateway Master
  • 4,806 Answers
Ok there area few things you can try to get to the bottom of this, firstly remove the battery and try it on AC power only, check that the memory is free of dust and is seated properly
post back with the results please
Posted on Dec 12, 2008
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Dec 12, 2008
    Ok sounds serious, remove the battery and AC power and leave it off for a while, then try AC power only again, if you still get no joy you can back up the hard drive by connecting it up to another computer as a slave device
    kind regards
  • Lee Hodgson
    it could be anything from faulty memory to blown processor or motherboard. sometimes disconnecting all the power removing the ram, hard drive and cd drive and leaving it off for a couple of hours can do it, while is off and the memory is removed press the on/off button a few times, this might reset the bios which also could be corrupt
    kind regards
  • Lee Hodgson
    it was stuck on power saving mode, if you go to the control panel and then power options you can dissable the computer from going to sleep.
    I am a PC technician and have come accross this problem many times before, its just knowing how to deal with it and is mostly associated with Vista, remember to relay this information to your bf, as this may occur again and he'll know what to do
    I think that deserves a Fixya! rating don't you?
    KInd regards
Hp pavilion desktop won boot
test the power cord+ outlet for faulty with multimeter. However if this things are o.k You must test the power supply pack for faulty, test the 5 vdc+12vdc, etc and see if there are Faulty. and replace. Please tight cable or connector inside. Test too the small battery for CMOS for +3vdc and replace.
God bless you
Nov 06, 2013 | Computers & Internet
Thermal shut down on Gateway 500r
Have you checked whether the CPU fan is working or not
Sep 27, 2008 | Gateway 500GR PC Desktop
Purchased a used compaq S5300NX desktop with monitor,keyboard,mouse, and other devices.First thing I did,was hookup the tower to my monitor,keyboard,mouse and internet connection. turned it on and it...
If there is noise "beep" then it has RAM issue/RAM port. If is not noising then it has motherboard issue. I guess you need to take it to the technician and ask him to fix or replace it.
Nov 04, 2013 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
My car won't start in the cold weather. I don not have Power Locks or Power Windows. What is the Problem?
That sounds like a battery issue. Batteries have whats called CCA (cold cranking amps) it is the main thing to pay attention to. This is a measure of how much current the battery can provide at 0 deg F. Batteries work better when they are warm, so the colder it gets, the less current it can provide.
Starting an engine requires a lot of current, over a very short time. Meanwhile, cold engines are harder to start, requiring more power to get them going. So look at your battery and its CCA and since u said u bought the car a few years ago. You probably didnt replace the battery yet have u? Batteries usually have a life of 4-6 yrs only. Hope this helped
Jan 23, 2013 | 2003 Saturn ION
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Administrator password forgot
I also forgot the password of my Dell a few days ago,but I recover
windows password now by a software called Windows Password Reset,
it is easy and effictive to use,and all systems support.
I hope it can work out for you.
Mar 04, 2012 | Microsoft Windows XP Professional With...
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
Two month old Gateway DX4300-03 randomly shuts down when on the internet.
I have the same pc my power supply went bad after 2 weeks.Pack up the pc and return it ASAP I have nothing but problems with mine.Gateway use to make good pcs, those days are gone,mine was a gift and I had to keep it.
Nov 19, 2009 | Gateway DX4300-03 Desktop PC
Gateway cordless mouse intermittent connection model MR-0610T ,,, came as a set with keyboard. keyboard connects fine, no problems, but mouse has to continually be reset after a few commands/minutes.
I was having the same problem then I ran across something on the Gateway sight saying to hold the connect button on the transmitter for 5 seconds, then the connect button on the mouse for 5 seconds. I just did this about 5 minutes ago but it seems to have fixed the problem.
Feb 23, 2009 | Computers & Internet
Non Displaying any things for a 5 to 10 minutes in first instance startup
this may seem unusual but try unplugging power cord from the back of computer for 5 minutes then fit power cord and try again sometimes the bios get upset and has trouble finding hard drives etc.
Jul 25, 2008 | Intel DG31PR Motherboard
Gateway M305CRV Notebook Logo
239 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
