I have a LG refrigerator # LSC 27950ST there is two ice and water lines that runs on the outside of the back of refrigerator that are attached to the bottom inlet pump and runs also to the top and into the refrigerator and is attached to the water filter that sit's at top of inside of refrigerator one of the lines is spit and leaking water part number is 5210JA3004K items 616F I can remove the damage part from the bottom which is attached to the pump, but i need to know how to remove the damage line from which it is attached to the water filter with out damaging the refrigerator?
I recently looked at a filter housing... the waterline was an integral part.
You can get press fittings... or may have one You have only to push the tubing into the fitting. To release you need only push the collar around the fitting to release.
When the WORLD figures out how EASY these new shark bite fittings are...
Plumbers are going to have to get really competitive!!
Ice Maker Installation Kit Quickly Install Ice Maker Water Valve
http://www.homedepot.com/p/SharkBite-Ice-Maker-Installation-Kit-25024/206105353
Carnac the Magnificent
You may need a plumber
SOURCE: LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
