Question about Canon IXUS V2 Digital Camera
Battery no matter what type of batteries i put in my camera, they do not work. the battery symbol always comes on, and the camera eventually shuts off! i've tried several different batteries and troubleshooting ideas in the handbook. please help!
    Genius:
  • 1,689 Answers
If you know for sure that the batteries are fresh and are in good condition, it is possible that the camera's internal power inverter has gone defective. You would need to send the camera to themanufacture to have it serviced.
Jerry G.
Posted on Dec 12, 2008
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
The batteries always seem to drain shortly after putting them into the camera, no matter what type or brand of battery I use. Help!!!
?? Drain as in leaking. If the camera makes the batteries leak you should contact KODAK immediately and they will make a HSE case for you. Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If you mean the camera is drinking batteries try these steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 20, 2010 | Kodak EasyShare C633 Digital Camera
Hi I have just put brand new batteries in my canon powershot A560 and having taken approx 4 or 5 photos it is now telling me that my batteries need changing. The low battery symbol is also on alot of the...
Make sure that you use the correct type of batteries some cameras prefer Alkaline or Zinc Carbon both at v1.5 some only can take 3 rechargeable Nickel Cadmium (Nicad) Cells at 1.3V (3x1.5v= 3.9V) or one Lithium Ion at 3.6V
Be careful if you put a 1.3V NiCad Rechargeable in a camera that was designed for 1.5 Alkaline it can damage the camera and you may experience similar problems to that you have now.
Always check that you are using the recommended batteries, this is why most manufactures supply there own Lithium Ion 3.6V rechargeable K type cells to avoid this type of problem.
Jan 06, 2010 | Canon PowerShot A560 Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Canon powershot SD 550 Digital Elf
Have you actually replaced the battery or not? You said you tried ordering batteries. You can buy an SD550 battery on ebay for about $6.00
Also, the battery charger may be the problem. The charger has sensitive electronics on beaord that can be damged by a power surge, even normal use can eventually take its toll.
The battery will always hold enough power for the camera to to say "please Change The Battery Pack" on the LCD screen.
The camera would never allow the battery to become completely drained, as that would damage the battery.
Last but not least, put some alcohol on a cotton swab and carefully clean the battery contacts inside the camera's battery compartment.
Good luck
Oct 30, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Change Battery Pack _ Ixus 70
Hmmmmm, the only thing I can think of, are you using the correct type batteries ? Check your instruction manual for the correct type of batteries, if you still have a problem I send it in for repair work or return it if it's new. Good Luck
Jun 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Batteries????
i had that same problem didnt matter what strength the cameras were still wouldnt come on went and bought rechargable batteries and now its ok
Mar 21, 2008 | Olympus FE-140 Digital Camera
Canon IXUS V2 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
