Question about Samsung SyncMaster 910MP 19" LCD Monitor
Color and other problems with SyncMaster 910 MP monitor
About a month ago my monitor started to behave strangely. First it just went black for a few seconds and then came back on. Then sometimes it wouldn't come back on and the only solution was to unplug it and plug it back in. Then once the screen turned blue-green, another time the image on the screen began "rolling" horizontally, another time I got vertical colored bars. Then a few days ago I got a box that said "image adjustment, please wait," and everything turned pale yellow. After rebooting it looks almost normal, but is still very pale.
I do not have an instruction manual because I bought the display model off the shelf at Best Buy and it didn't even come in a box. Please walk me though step-by-step how to fix this. Thank you,
Carolyn
  • imjustified Jan 02, 2009
    Back in 3/04, I purchased a ViewSonic from BestBuy; paid $799. About a year later (6/05), it went out (unresponsive). The good news; it was under warrenty. The bad news; it was discontinued. The best that Bestbuy would do was to replace it with a SyncMaster 910 MP, valued at $688. So, I said yes. Yesterday, (about 6 months after my warrenty expired) my 910 started acting strange. The colors are wacked--very deep red, not able to adjust color. (I switched monitors to see if it was my video card. The computer is OK, my 910 is not.) BestBuy told me that they'd charge $35 to look at it to see if it's repairable. Should I even bother?
  • 231 Answers
Go to => http://www.samsung.com/us/
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Posted on Dec 23, 2008
  • Suzanne
    Suzanne Dec 23, 2008
    Also, check to see if you are running the correct video driver for the monitor. It's best that you download the lastest driver.
    Another thing to check is the VGA cable. A loose cable can cause the monitor to go funny. Run the self-test. If the colors are okay, it could be a bad cable.
Samsung syncmaster 245b lights up and then turns black...
more than likely your video card has gone bad .. try to get a new video card and install it or take computer to your computer shop and have them replace it for you
May 17, 2017 | Samsung SyncMaster 245BW Monitor
Tip
Hi. I just got my samsung syncmaster 920nw less than 6 months ago, and now i...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
My mp 240 is showing an error P3
P, THEN 0, THEN 3 RIGHT?
Strange thing. I have had this particular printer in question for about a year now. Today I got a similar message, but with an 8.
I ran out of color a while ago and never replaced it, just used the black only feature. That ran dry and I replaced the black and only the black. It has been running just black for many months.
When I researched my problem I found that it may be linked to my color cartridge being out. (but it has been out, for many months).
Nonetheless, I installed a new color cartridge and voila!.. Problem solved.
If you have a cartridge that is low or empty, change it and see if it solves your problem. (Be sure to keep the receipt in case it doesn't work).
Jan 25, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 19, 2009 | Samsung SyncMaster 920NW Monitor
Changing in satelit TV from Radiocanal zu TV chanal
LOOK IN YOUR LOCAL PHONE DIREDTORY UNDER COMPUTER CABLE SPECAILIST, CALL THE AND SEE IF THEY MAKE THAT SWITCH FOR YOU, 99% TIME THEY CAN MAKE THAT HAPPEN FOR YOU ANOTHER OPTION IS A TV SHOP THAT BEEN IN BUSINESS FOR 20+ YEAR MAYBE TO DO ALSO.
ROD
Feb 09, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
WHERE CAN i DOWNLOAD AN INSTRUCTION MANUAL
hi
here is the user manual
http://www.fixya.com/support/p394862-samsung_syncmaster_910mp_19_lcd_monitor/manual-3916
Feb 02, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 910MP 19" LCD Monitor Logo
395 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
