Question about Jensen XCD9722
Setting clock?? I bought a used car with one of these stereos installed. It's great, the only problem is that the time is completely wrong and I have no idea how to fix it. Any help would be appreciated!!
2 Suggested Answers
SOURCE: setting the clock
after pressing the display button, and the clock starts to flash, press the up-down (volume arrows) for the hour and the side arrows for the minutes.
Posted on Mar 03, 2008
SOURCE: Jensen CD3720 car stereo unit face plate LCD display blanks out.
The substrait is probably cracked, that's the circuits inside the pc board of the faceplate. It will cost you too much to try to have it repaired. If you will wait for a few days I may have a face for it as I'm currently trying to fix one that is blowing fuses. I'm not going to spend a whole lot of time on it. I'll let you know.
Posted on Apr 08, 2008
0 characters
1 Points
Set time
Go to:
Jun 13, 2013 | Car Audio Receivers
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
# To return to the main menu, press and hold
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
Sep 26, 2009 | Pioneer DEH-2100 CD Player
Setting the clock
For finding Radio user manuals - it is best to exhaust the manufacturer's resources before downloading a file from a potentially harmful site. Click the following Brands to navigate directly to their SUPPORT page to look up the model number of the radio you are looking for. Alpine
Panasonic and are also great resources to find the oddball or older model guides. If you are looking for an installation guide, the industy-wide color chart can be found by CLICKING HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 09, 2009 | Alpine CDE-9846 CD/MP3 Car Stereo
Setting clock
Use MULTI-CONTROL to select click.Clock appears is the display.
Pushing MULTI-CONTROL left or right will select one segment of the clcock display: Hour - Minute
As you select segments of the clock display the segment selected will blink.
Pushing MULTI-CONTROL up will increase the selected hour or minute,down will decrease the hour or minute
Mar 24, 2009 | Pioneer DEH-P6900UB CD Player
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
How to set the clock on the car stereo (Naxa nx-670)
I had the same issue. I bought my 671 mp3 car stereo from and I was having the same problem. I called them up and they said that I have to go to clock mode. When in 'Clock Mode' you have to press and hold Select (SEL) and at the same time press FF/REV to adjust time. (Fast Forward adjusts hour, Rewind adjusts minute). If your still having problems contact the Naxa Electronics warranty department. Goodluck!
Jan 17, 2009 | Naxa Electronics NX-671 Car CD/ MP3 Player
Setting the time on car stereo/cd player
Changing the general settings
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
3 Select the PSM item you want to
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Setting the clock:
1: Press and hold the select button. The setup display appears.
2: Press the select button repeatedly until "CLOCK-ADJ" appears.
3: Press SEEK +. The hour indication flashes.
4: Rotate the volume control dial to set the hour and minute.
5: Press the select button. The setup is complete and the clock starts.
To display the clock, press DSPL button. Pres DSPL button again to return to the previous display.
May 24, 2008 | Sony CDX-GT310 CD Player
Car Audio Receivers Logo
16 people viewed this question
Top Jensen Car Audio Receivers Experts
Tygh Duval
Tygh Duval
xxxxxx xxx
Are you a Jensen Car Audio Receiver Expert? Answer questions, earn points and help others
