Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell CT3611 thermostat malfunction
I have a honeywell CT3611 thermostat and a york heat pump (E2CS030A06A) and I'm having problems with the fan and auxillary heat turning on and off to maintain the indoor temperature. My indoor unit has wires connected to C,G,R,W1,W2 and my thermostat has wires connected to C,R,W2,E,W1,Y,O,G but no wires to B,L. I followed the guide for the thermostat wiring however the fan does not work when I place the control on "continuous" and the aux/supplemental heat does not turn on on the indoor unit eeven though the thermostat indicates it's on. I checked my aux/supp coils and they are working fine. Someone please help.
  • vasilios_pap Dec 16, 2008
    Hi Jack,
    Thank you for your help. I bought the house in 2001 and it had a York heat pump/electric furnace. I had an old mercury switch thermostat which I replaced in 2003/4? with a Honeywell thermostat. I noticed problems originally with the fan however it wasn't critical. Last week when the temp outside dropped to -25C, I noticed that my indoor set temp of 20.5C was dropping and that my auxillary heat wasn't starting. My heating guy had told me if I ever needed aux/emergency heat to just attach/detach a wire to turn the coils on/off however I never needed to do that since I had installed the thermostat. My heating guy is not familiar with electronic thermostats (he is 63 years old). This is how I'm getting by, I get up in the middle of the night to detach the wire and by morning the temp inside is 19C. I have not changed anything on the heating system except for the thermostat. I hope this answers your question.
    PS-How do I reply to you aside from adding a comment?
  • 10,515 Answers
A very common occurrence with service calls is the complaint that the thermostat isn't working properly. Sometimes this is true but often it is something entirely different than the thermostat. Because some people believe the only problem with the system rests with the thermostat, they'll go down to the local hardware store and purchase a brand new thermostat. They get home and dust off the tool box, never read any thermostat installation directions, and proceed to change the thermostat. Some are successful at changing the thermostat and some are not. Those that are most likely read some thermostat installation directions or had someone read the thermostats installation directions for them. The ones that are not successful end up calling a professional in to install a new thermostat.
The bottom line advice to most people is to call an HVAC professional if something is wrong with your thermostat or HVAC system. The problem may not be with the thermostat and you may exasperate the problem which will cost more in the long run. Additionally, If you have a multi-zone system, a high-efficiency heat pump or even just a heat pump, a regular split-system AC and a boiler for heat (and you have one thermostat), or an Apollo based system (hot water heated in a water heater) with a split AC system....... call a professional. These systems can be very complex and may require special sub-bases so the thermostat control circuit will work properly. Additionally, for heat pumps, there are different controls, and wires for these controls run into the thermostat, they are multi-colored thermostat wires. These controls can be very complex and each wire must go to the correct terminal on the thermostat or the unit will not run correctly. There are so many different variations to this High Performance HVAC will not attempt to describe them here. We will describe the common type (at least for this region (mid-Atlantic) and if you see that you have the system described you can proceed cautiously at your own risk.
Additionally, be aware that thermostats are equipped with heating and cooling anticipators. Cooling anticipators are not adjustable where heat anticipators are adjustable in mechanical thermostats. Setting the heat anticipator is important for your heating system and thermostat to function properly. It is set according to the amp draw on the control heating circuit. Make sure the heat anticipator is set properly in the thermostat or thermostats so you will get the best out of your heating system and your thrmostats.
Posted on Dec 16, 2008
  • 304 Answers
i would like to know first if you have replaced and changed a spare parts..?
which of the parts have you replace, and may i know the first problem occurred happen..
  • 19,396 Answers
I think this is the same wiring diagram as your model:
  • Ginko
    Ginko Dec 16, 2008
    Here is a breakdown of your wirings:
    The C terminal is common power.
    The G wire is the fan
    The R is the 24 volts wire
    The Y is first stage of heat
    The W1 is second stage of heat
    The W2 is third stage of heat
    The O is the contact to reversing valve.
    B and L are relays. B is heating changeover relay, and L is emergency heath relay.
    Follow instructions and diagram on the manual to do the wiring.
  • Ginko
    Ginko Dec 16, 2008
    The emergency heath relay is L, if you did not connect L to the thermostat, this wont start the relay, and wont kick in the heath pump.
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
I have a York Unit and a Honeywell thermostat. Our unit froze up and I was told to activate the emergency heat. I did this, what does this heat do? I mean how does it work? When do I set it back to...
by going to emergency heat you have shut off your heat pump and turned on a back up source,either gas or electric, if its cold out,35or less ,just leve your emergency heat on till it warms up a bit
Jan 10, 2011 | Honeywell Programmable Thermostat Heater
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
473 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
