I keep getting this message that says Windows encountered a critical problem and will restart in a minute and to save my work over and over again I need help PLEASE!!!!
Try this first....
You might have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
SOURCE: i have a asus x53s laptop when i boot up
This is a pre-crash stage of Windows. Re-install Windows by following the link given below as a guideline:
Crashed Windows : No Problem
SOURCE: I just bought ASUS K61IC-x3, where is preloaded
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
SOURCE: Do you know Asus Laptops? I need a manual for the
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
SOURCE: I have an ASUS U52F
There's a few things that could be the cause but the first thing you ALWAYS want to check on a laptop with network connection problems is that the wireless switch is in the on position. It should be located on the left side of your laptop if it's facing you. Here is a picture if you still need help to find it.
ok it's ok Start your pc once you get to the ASUS screen tap the button to get into your bios or "Setup menu" most likely F2 once done you should get a menu goto SATA DRIVE or SATA TYPE or just SATA either (achi or IDE modes) change from (IDE to ACHI) or from (achi to IDE) ok if that does not work please feel free to reply
