When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Posted on Dec 12, 2008
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
I have a samtron 74v and upon booting up the screen stays black and a message flashing across my screen says "no optimum mode, recomended 1280 x 1024 : 60hz" but how can i change the resolution and...
Running XP? Boot the PC in safe mode (hit F8 key while PC is booting up and select safe mode), then set the video resoltuion to 640 x 480, reboot into regular boot up, reset the video resolution to 1280 x 1024 @ 60Hz.
Mar 19, 2010 | Samtron 74V 17" LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Changed screen resolution. Now when turning on computer and monitor a message appears " is screen resolution correct? If any key is touched the monitor goes to standby.
try to boot on safe mode, by pressing f8 while booting then choose safe mode,
while in safe mode you can set the resolution back to its default .
Sep 11, 2008 | Computers & Internet
Blank screen
was it working before
check all your cables and lines make sure a pet didnt get behind there also if you have kids make sure they didnt put liquid into your comp
cause if it was sounds like you got hit by a virus that effects all major compartments of comp
green to yellow is standby mode
May 30, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Computers & Internet Logo
David Payne
David Payne
