Question about Samsung WF337AA Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
I put a down-filled pillow in my samsung on the deep steam cycle. needless to say, all i had left once it was done washing was wet feathers and a pillow case. i cleaned out my hose and the filter at the bottom that were clogged with feathers, yet it still will not run. is there something i can do to fix it? this is a samsung WF448AAP silvercare front load washer one month old.
  • Anonymous Mar 24, 2014
    A hose attached to a plastic t pipe keeps popping off. It is possible there is a blockage in a compartment
Dont put expensive pillows into a washing machine.
Posted on Mar 08, 2009
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Can I clean the steam kit DC97-09101J or do i need to re-order?
I would recommend having someone look at the machine. There are a few things that could be causing this to happen (The hose, your steam sensor) and it's better to spend the $ on getting it fixed than just purchasing parts that may or may not fix the issue. Good Luck!
Apr 20, 2014 | Samsung WF448AAP Front Load Washer
Washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Sep 05, 2012 | Washing Machines
Washer is not draining. I have checked the pump filter & when I drain the water, then the machine will start once again; however when water comes back in, then I have to drain it again. I have only...
I have the same problem with the WF448AAP--I have cleaned out everything, run several cycles with a AFFRESH tablet--that seemed to help a little. Residue (white) has been found in the filter--cleaned it out as best I can. Still have the problem.
Does anyone have a solution?
Jun 05, 2011 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
A feather pillow busted during the cycle - What do I need to do to prevent damage?
either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Jan 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
Samsung WF337AA Front Load Washer Logo
738 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
