Question about Amana ARSE66MB Side by Side Refrigerator
Water dispenses randomly
My husband had to unhook all the lines and wires that supply our ice maker/water dispenser because they were clogged after we had some plumbing done on the supply lines. since then, the water dispenser will come on everytime the compressor? comes on. It is happens regularly and you can hear something kick on and then the water comes out for about 2 seconds. He said he unhooked some wires and wonders if he may hav hooked them up backwards. He has moved the wires around and is now unsure of what else to do to fix the problem. the next step is a service call.
  • mstnglvr Apr 20, 2009
    i have the same problem.  but no work was done on the refrigerator pryer to it happening.  It just started happening one day.  What did you do to fix it?
Take the water lines off and blow them out and change the filter it sounds like the linesare pluged
Posted on Sep 24, 2008
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
26 side by side with ice maker doesn't work
The water control valve can get clogged or fail. Follow the line from the supply( did you check for filters there?) to the bottom of the fridge. The valve may be just like the one on a washing machine. It has a wire filter in it too. Test it for flow, unhook the pipe to the ice maker and see if water comes out of it when it is energised. I made a test energiser out of a power cord with the same connectors that the valve has.
Apr 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Wont dispense ice or water
Hi
Please follow this :
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Please revert for any assistance and Do accept this solution.
Thanks
Rylee
Mar 21, 2009 | GE Refrigerators
Amana ARSE66MB Side by Side Refrigerator Logo
113 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
