I have a tripp lite SU 1000XL UPS that I bought and had not used. I un boxed it and plugged it in and it will not power up. The circuit breaker in the back is good and the 4 fuses inside are good. I don't even get a line voltage indicator light. It is completely dead.
    Sergeant:
  • 320 Answers
First thanks for choosing fixya.com
Most times a new ups does not have its internal batteries connected yet. Follow the manual to connect the batteries. If they are already connected plug the device in for at least a day to let them charge. Make sure nothing is plugged into the UPS durring this time. Also make sure you have pressed the "Power" button on the device to turn it on. Some have a switch on the side while others have a button on the top where everything plugs in.
Hope this helps.
Jei.
Posted on Dec 13, 2008
Tripp lite problems
Look for a little breaker button on the side of the unit. If there is one, press it in and the unit should recover.
Jul 26, 2014 | Tripp Lite Smart Pro SMART700SER...
The LCD display no longer works on my Tripp Lite Omni 1000 LCD. Also, half of the power outlets on the back of the unit no longer work.
Be aware.
My Tripp LIte Omni 1000 LCD almost caught on fire.
I had been experiencing a spike in my power bill to the tune of 1000 Watts an hour for everything running - 24x7. I started the survey of all my equipment; TV 162 Watts; Fridge 228, etc. but none of these devices are on all day and night. I finally mapped out all the outlets and lights and was about to begin the survey. Other than the flickering lights, one big clue was that my TL's lcd was displaying a spike in voltage DOWN to 95 or so, the relay would click, etc.
I decided to begin my survey and use my second TL to help me see which circuit was faulty. When I looked at the LCD, it was blank. I pushed the ON button and all the devices plugged in went OFF and then I saw smoke coming out of the back. I quickly unplugged everything and then watched my meter. When this UPS was plugged in, there was about 1000W used per hour; I monitored it for 10 hours; 400W were used (total).
So... not only was it a fire hazard, but it sucked up 900W or so an hour.
Nov 28, 2010 | Tripp Lite (OMNI1000LCD) UPS System
No output voltage
Well, it's a THERMAL fuse and not one rated at amps...but temperature. I'm working on a value of temp that will work in reference to the 25 amps the round cylindrical fuse is rated at.(And the outside the unit re-settable circuit breaker.
Nov 03, 2010 | Tripp Lite Lite Internet Office 280 UPS...
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
After a short power outage (resetting breaker) the protected outlets no longer provide power. Is there a way to fix or do I need a new UPS?
The unit may need to recycle itself. Remove the loads and turn the unit off. Plug it back in, wait a bit, then turn it on. Then try your loads on it again.
Feb 18, 2010 | Tripp Lite Tripp-Lite HT1500UPS Home...
Smartpro UPS dead
APC UPS not turn on if battery are dead (zero volt) or un-plugged.
Oct 16, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
I need help in hooking up a new circuit breaker for my internet office 450. Does it matter which of the two wires I connect to the breaker?
If there is only two wires, the breaker is a current sensing device which connects in series with the circuit. which wire goes where should not matter.
Oct 10, 2009 | IBM Tripp Lite Internet Office 500...
Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Jun 03, 2009 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
TRIPP LITE UPS MODEL:5000HW WILL NOT START
Hi Godfrey,
Its very difficult to get a circuit diagram indeed. Did an extensive searching . Not sure if this would help you . Please click on the link bellow.
http://images.google.com/images?gbv=2&hl=en&sa=1&q=tripp+lite+circuit+diagram+for+UPS&aq=f&oq=
Now once the page opens you would find a number of circuit diagram. You can click on the required image to enlarge it.
Thanks
Apr 30, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
Replacing batteries on a Tripp Lite Smart 2200
hi there
tripp lite includes battery replacements and they have authorized sellers and distributors. however, they dont sell directly to consumers like us. they do have sales and support if you want someone from them to have the battery replacements installed
call there Customer Support (773) 869-1234
or visit there online site for more details.
http://tripplite.com/index.cfm?countryid=122
hope this helps.
Feb 07, 2008 | Tripp Lite Battery Finder: SMART2200RMXL2U...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
