Question about IBM Thinkpad T20 Notebook
I got a thinkpad 2635 yesterday from a friend and upon powerup it displays an error message with 00161 and 00163 printed under it with two options ok and cancel what do i do to get into this thing
  • IBM Master
  • 32,281 Answers
These error message relates to the BIOS and it appears the BIOS battery requires replacing because it is flat.
error 161 usually BIOS has lost its configuration/ checksum error.
error 163 usually BIOS clock not updating.
Replace this battery and go into the BIOS setting and configure the date/time settings, and hardware settings (if you are not sure select the factory default settings) save and exit
Posted on Dec 12, 2008
What do i do when my thinkpad says error
Reboot your machine while holding the F8 key as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
The os will start in safe mode. run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is may be a hardware problem.
Good luck.
James
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 25, 2010 | IBM ThinkPad 380ED
System error
System error upon print option may be caused due to:
  • Improper device driver (printer).
  • Any corrupt file.
  • Any hardware error
Check all these before you start printing, Try to check a test print also..
Jan 21, 2010 | Brother P-Touch PT-2600 Printer
Ibm 2635 thinkpad
You can get an adapter such as an DB9/com port to USB or LPT to USB adapter and you'll be able to connect a USB device or USB hub to your ThinkPad.
Feb 18, 2009 | IBM ThinkPad 380ED
IBM 2635-6AU
update bios ibm thinkpad type 2635
Oct 02, 2008 | IBM ThinkPad 380ED
IBM THINKPAD 2635-5AA 380ED ERROR 174
Your problem sounds like the system isn't finding the hard disk
May 01, 2008 | IBM ThinkPad 380ED
00161 and 00163 errors
had same problems changed small battery under cover near normal battery solved problems cr1220
Mar 20, 2008 | IBM ThinkPad 380ED
IBM 2635
I just dug my old 2635 out from under the couch and having the same issue. I'm wondering if the internal battery needs replacing - this would give power to the system ROM where the date and time is held. I'll let you know if I find anything.
Troubleshoot IBM laptop
The answer is very simple, Use Restore disc to Reinstall the Operating system.
Feb 06, 2008 | Computers & Internet
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
IBM Thinkpad T20 Notebook Logo
141 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
