Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Stop light keeps flashing
The stop light on my washer/dryer keeps flashing and no program will run. When i chose a program it makes the usual noises and the stop light is flashing but it never stops and the door lock doesnt engage. I've emptied the filter, reseated the water supply and unplugged the machine for at least 10 minutes but still no joy. No other lights are flashing, i've tried pressing different buttons but the only activity is the red stop light flashing. Any ideas would be greatly received. Thanks Simon
jackboy
  • 2985 Answers
SOURCE: Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Posted on Jul 31, 2007
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
  • 1122 Answers
SOURCE: Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Posted on Oct 31, 2008
SOURCE: My Hoover VHD8142 stops whilst
I've just had exactly the same problem with the same model. Unlikely as it may sound, it's the heating element. Mine has just been replaced and everything is now working perfectly.
Posted on Jul 22, 2009
jan mczeal
  • 632 Answers
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 22, 2009
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer making a weird noise
forgot to include the most important step! We got the dimes out after wadding up a small piece of duct tape, sticky side out, and using locking forceps to grip the tape while fishing out the dimes from the drain pump.
Sep 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Aquarius
i have the same problem if you find out please let me know...... think may need a new program for machine would be cheaper to buy new one all together
Jul 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryer doesnt work on hoover nextra HNWL 6136
I say replace power control module
Feb 02, 2008 | Washing Machines
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
66 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
