Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Water beneath my salad bin
I have a FFA70 fridge and I keep getting water beneath the salad bin, the gutter drain is not covered and is not blocked but water does not seem to go down the hole, please can you give me some advice. Many Thanks
  • help_needed2 Feb 09, 2008
    I've had the same problem had to unplug the appliance and defrost it, which worked for a few days then back to the problem. any suggestions would be grateful.
I had a blocked refregerator drain, would not clear at the top and when explored downwards with a long thin wire it stopped just short of the evaporator tray on top of the compressor. Removed the air ducting inside the freezer part and found the cooling matrix was half blocked with solid ice. Warmed and cleared all that and guessed that the solid ice everywhere was close to where the refigerator drain block seemed to be. Sure enough after thrawing the WHOLE unit completely I managed to remove a 6-7 cm slug of solid ice from the refigerator drain hole above the evaporator tray.
Reassembled and working fine and drain is clear!
Freezer fan is working less hard too.
Posted on Nov 20, 2011
TY NOGGIN FOR YOUR ADVICE FINGERS CROOSED I THINK U SOLVED IT MANY THANKS AGAIN LES FROM LIVERPOOL ENGLAND lessambekjo@hotmail.co.uk
Posted on Jan 09, 2008
  • 944 Answers
If the drain is truly not blocked then the water will go down it. try poking a piece of thin wire down it to check, and have a look on the outside at the back - some models have a tray or tank where this water collects that may be full - else the fridge drain should be plumbed into a drain - check from the outside too. Also check if the fridge is truly level. The feet allow you to adjust this and see - sometimes a small change in angle can spoil the drainage characteristics of these machines (possibly even lean it backwards a little if it looks like this might help). the only other possibility is if the fridge drain is fixed into another drain, that another appliance or fixture is causing back pressure - if so you would be able to see bubbling into your fridge if you sat and watched while someone else ran all the sinks/toilets/washers/dishwashers etc around the house - in theory though when all these other items are not running then the water should still drain.
Posted on Mar 10, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 10, 2007
    also there is often a small plastic piece that sits in the drain hole without blocking it to break the surface tension of the water - if you dont have one then the top end of a simple plastic cocktail stirrer with about an inch (2.5 centimetres) of the stem sticking down the drain hole - so long as the top of the stirrer or the stem doesn't totally block the hole then this may work.
    see first if you still have the bit in a bag with the manual and warranty and those mystery screws in the back of a drawer somewhere.
    try this idea by poking bit of wire in drain with water there and see if it goes down.
    Hope this helps too :)
  • Nigel Ridehalgh
    have a look at a couple of other fridges or in a dealer and you are sure to see one of these items - the dealer migbht even have a bag of them to give away.
Water is collecting at the bottom of the fridge under the salad trays constantly
Whenever that happens on our fridge we find that the drain out the back is blocked. Have a look inside the fridge on the back wall, you may see some guttering that guides the inside moisture to a hole. That hole drains to a pan on top of the motor. Heat from the motor evaporates the water. I have always managed to clear ours by poking a bit of flexible wire down the hole. It's not a frequent occurrence, probably 7 or 8 years between blockages.
Aug 11, 2015 | Refrigerators
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
The water is no longer going down the drain at the back of the salad bins. I've tried straw, electrical flex but they hit an obstruction at a depth not far short of the drainage tray. What could I...
Greetings,
its most likely ice...take a squeeze bottle or tubing and force water into drain opening. I use a 1/4inch tube and blow into it and then **** some water out and continue this until open...
Jan 06, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Fridge smells
The drain leads to a pan under the fridge that sits on coils and evaporates the condensate that drained out. you should be able to access the pan and remove it and clean. or you can just wait for it to evaporate and go away. (better off to clean) some warm water in a baster will help rinse out the line. Let me know if that worked or if you need help accessing the pan.
Oct 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
530 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
