Why does my Nordictrac c2300 start and stop?
It could be because it is overheating due to the fact that the floor belt is too dry and the motor is labouring hard to spin the floor belt. When was the last time you lubricated the base of the floor belt (the flat base where the floor belt slides on)? A couple of little sprays of Silicone Lubricant should ease the motor workload as the floor belt rolls on. If you're a big person, the excess weight also tempts to dry the floor belt quicker and if you're running on it while the home is being heated in winter of during warm summer days, or you are training on carpeted or linty areas, all the excess heat and dust dries the floor belt faster and need to be lubricated more often. Lift the floor belt and feel with your hands if there is any lubrication. A wet feel means it is lubricated, while a dry feel or sticky hand as you move your hand left and right means it is dry. Dry belts are the blame of 80-90% of motor failure and or seizures due to lack of care and maintenance. Lubricate it once per month. If you don't like spraying Silicone lubricant directly under the floor belt, do this; find a lint-less rug such as a kitchen drying cloth and go outside the house, spray the Silicone lubricant on the cloth to lightly soak it and then go to the treadmill, lift the floor belt and apply the wet cloth evenly on the base until you believe it is lubricated enough to make the rolling of the belt with ease. Run it for half a minute at slow speed (walking pace) before you can safely use it for running or jogging, etc.
