Question about Dell Dimension 3100 PC Desktop
I have no sound on my system. the drivers have been installed twice.
    Master:
  • 474 Answers
Hav you checked all audioo controls? In windows, just asking, some people dont even try this. If so, take some earphones, plug into the front and back connections ( if applicable), while some some music file is playing.
Let me know if you get anything from one or the other, or not at all.
Also, do you have a sepearte AUDIO CARD installed or just the onboard?
Also, how did the issue come about? Suddenly without warning or while you where messing around with controls.
Posted on Dec 12, 2008
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Dec 13, 2017 | Toyota Highlander Cars & Trucks
How to install sound driver
  1. download the driver from thins link
  2. setup (install by clicking twice on downloaded file)
  3. enjoy !
Dec 21, 2010 | Dell Audio:Sound Blaster 64 PCI Driver
Sound driver problem in compaq presario cq40 with winXP
update to service pack 3, then go to update driver in device manager and allow it to search the internet it will find the HD audio codecs from microsoft and install them.
Jul 02, 2009 | Compaq Computers & Internet
Unable to install Audio driver in Intel DG31PRI board for Windows 2003 server.
You can’t install DG31PRI board sound driver automatically it install manually
Go to cd room drive right click and open your main board driver cd
Then find sound driver then install sound driver manually. Click twice then
Next –next-finish.
Bibekpaul@in.com(india)
Apr 29, 2009 | Microsoft Windows Server 2003 Standard...
No sound since installing xp
Unfortunately your best bet on your Inspriron 531s is to go back to Vista. According to Dell, this system was specifically setup to run Vista and, therefore, no XP drivers are guaranteed to work on this model. Most of the time for onboard devices, if they are not listed on the site, they are usually native to the operating system and do not require a driver download. Dell does, however, have some XP drivers for this model listed on their support site here
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=INSP_DSKTP_D531S&hidos=WW1&hidlang=en
The only audio driver listed is for a Creative Labs X-Fi sound card and I am not sure that is what you have. Your best bet is to uninstall your sound card drivers, reboot, then install these. Good Luck
Apr 23, 2008 | Microsoft Windows XP Home Edition
PCI device problem
hey the pci device and the sound are seperate devices. I believe that he pci device is the modem, check to see if u have that already install. the sound and the modem might be the same manufacture thou.
dv2000 NB has conexant HD audio
conexant Modem with smartCP
drivers are here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1817074&lang=en
Jan 30, 2008 | HP Compaq Presario V2000 Notebook
Sound Card Not installed?
hi,
things you can check over here.
1. reinstall the audio drivers from the resource cd. in case that does not work ,download the drivers from
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
just punch in your service tag and select the sound card installed and download the driver
2. reset the bios. that causes issues after reinstallations.
you can do that by following the steps below.
press f2 key on the dell logo screen.
press num lock, caps lock and scroll lok on keyboard so that all three are on. press alt + e together followed by alt + f.
press esc twice and select save changes and exit and your system would restart.
hope that works and fixes the problem.
Jan 21, 2008 | Dell Dimension 4600 PC Desktop
Sound problems
Sound Recorder Help When trying to play a sound .wav file you receive the following error message: "Sound Recorder cannot record or play back because a sound device is not .
Computer Sound Card Help Line Out connector is the location which the speakers or headphones will be connected to get sound out of the sound card.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | Toshiba Satellite A60 Notebook
Dell Dimension 3100 PC Desktop Logo
Alun Cox
