We have an older Sharp copy machine, model SF-2114. It has been working fine and all of a sudden the copies came out with a heavy black line on one side of the paper. We put a new ink cartridge in and now it comes out with huge black smudges. Should we try to have it repaired? Is there something simple we can do, or should we just buy a new one?
SOURCE: I just purchased an imagerunner 2200 from liquidation sale the copies come out black
Hello Platanon,
I feel confident i can help you. And I cannot praise you enuff for the sample you have offerred. Nice touch, and extremely helpful. The drum on your machine is toast. Good news is that it is relatively inexpensive, and comes with instuctions to install it. The fact that you were sharp enough to provide the sample page of the poor copy quality artifact makes me feel VERY confident you will have no problem ordering a new drum and successfully installing it. Just to bolster your confidence, check this out. Notice how there is a pattern to the worst yuck on the page you submitted. It correspondes with the diameter of the drum (@ every 3.7 inches). The linear streaks toward the center of the page are another sign of drum wear. Canon rates the drum @ 55k +/-. You are officially fixed :-) . But if you need more help let me know .Take care...........SPINAL.......
SOURCE: Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
SOURCE: Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
SOURCE: I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
SOURCE: after changing toner on my sharp, SF-2022 copy
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
