Question about Refrigerators
I just replaced a water paddle on a frididaire refrigerator. When I reconnected the flat power strip to the power board on the panel, the ice dispenser started working and will not turn off
  • jcloyce Dec 13, 2008
    I have done that 4 times, doesnt work
  • jcloyce Jan 02, 2009
    Just got the parts, and the board was the answer. Thanks for the advice
  • 145 Answers
Cut power to the unit, carefully unseat that small ribbon connector on the control panel that goes to the control board and re-insert the ribbon connector, paying attention to the UP marks on the end of that ribbon.
Posted on Dec 12, 2008
  • Greg Angeli
    Greg Angeli Dec 14, 2008
    Then you may have to replace that control board. Did you get it wet or perhaps damage it in the process of replacing that paddle?
Water and ice dispenser stopped working
You will need to replace the dispenser control board on the door. Here is the part to order.
Dec 08, 2012 | GE Refrigerators
Ice and water dispensing problem; compressor shuts off when paddle pressed but dispensing is sporadic
could be the big motor that turns the ice in the bin when dispensing the ice. pull out the ice bin, check the big metal thing that turns when you press ice at the front dispenser. or you have a big chunk of ice that the motor can not turn.
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE PSC23SGRSS Side by Side Refrigerator
I have a Frigidaire model number PLHS67EESB9 side by side refrigerator. About 4 months, I has the water dispenser paddle replaced by a trained technician. Recently, the when the freezer door was opened...
Start by looking at the circuit boards for any sign of cracks or a trace coming off the board. Also, check all the ribbon wires for any signs of a break, corrosion, and so on. As soon as my database comes back online I will look to see if I have a service manual for that unit and any test procedures that you may do. Also, look at the door switch for any shorts or wire breakage. Post back any results to me.
Regards,
Richard
Oct 03, 2011 | Frigidaire FSC23F7D Side by Side...
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
Ice despenser won't sut off.
hi ggammon the dispenser is activated by the paddle that you place your glass against,then touching a micro switch .so i'd say you've got somthing amiss there and i would think only eyes on the ground can see what that is.i just said a prayer for you and you'll have to go back in there.in Gods service,tom
Jan 02, 2009 | Frigidaire FRS26R4A Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
GE Profile Refrigerator Ice/Water dispenser not working
Had the same problem. Pressed button heard a click, saw zeroes flash, then nothing. After some online search I found and solved the problem. Corrosion and condensation on the connector plug attached to the wire at the bottom of the freezer door. Remove plastic grill, pull out wire from under box. You'll find a plastic connector and possibly wet or corroded wiring. CUT POWER TO FRIDGE OFF FIRST. I cut away the white plastic connector then stripped and tied the wires together with wire caps. Taped them up too. Note which wire goes to which first. Mine was blue to blue, black to black, and red to white. Problem solved.
Aug 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
