Memory Problem Hello,
I have a Samsung Digimax A7 and no memory card. I am (was) able to take 30 pictures at a time and then I would load them on my computer, delete all the pics and go for another 30.
Now what is happening is after I deleted all the pictures from my camera I would go to take one and it is saying "memory full" but I have deleted all the pictures in my camera, when I go to review pictures it will say "no image" but when I go to take one it will say "memory full"
I have also deleted all video, audio etc.
Please help!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
please check the photo settings..you will be able to store more photos if you take photos in a lesser megapixel setting than compared to a higher one..also i would suggest getting a bigger memory card like 1GB..do check with the camera manual for all the supported memory types..hope it helps!
My camera has a setting buried in the menu somewhere and you just select "use card" instead of internal memory. There are only 2 options, internal or external. You'll find it.
