Question about Acer Aspire 3002LCi Notebook
1) Start up sometimes freezes, 2) Is not recognizing outlet power
1) Most times on start up, computer seems to freeze and/or take 20min-1hr to boot. AntiVir, Adware, Spywareblaster, Spybot SD, CCleaner, and Spyware Doc all say system is fine. Once computer is up and running, no problem even when restarted. But if computer is shut down completely and left for awhile, it's back to taking forever to come back up.
2) After adding additional RAM, computer is sometimes not recognizing outlet power; laptop runs very hot - fan does run.
  • sukhi_std Jan 21, 2009
    never start ,always hang-up,runs in safe mode
  • Acer Master
  • 1,800 Answers
Hi.
i recommend You in this Case to format and install a new OS
Windowns XP.
good luck
Posted on Dec 12, 2008
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
I have an acer one netbook /notebook---- computer freezes....worsenes w/tiime....sometimes it boots to windows then freezes,in safe mode .......still freezes....
CorruptedSystem Files
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen
Dec 02, 2010 | Acer Aspire One PC Notebook
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
Gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Dec 11, 2008 | Gateway M6307 Notebook
My Comouter Freez
place your cpu in the moisterise place if you start your computer without freezing then you can run fan/ cooler/ ac
Sep 21, 2008 | E-Machines (308714) Motherboard
Laptop problems...
I am having same problem and am going to fix the piece...... Ill let you know if I hear somthing and I would like the same in return pls :)
Aug 04, 2008 | Everex StepNote NC1500 Notebook
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
No Signal problem
your lcd need a tech who could help you to repair the power failure.
Nov 30, 2007 | Acer AL1913 19" LCD Monitor
Acer Aspire 3002LCi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
