Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven wont work and I can not set te timer to manual
  • Frigidaire Master
  • 3,463 Answers
If you have a user manual, then refer to that for instructions on how to reset.
If no instructions, and you have tried every possible combination of buttons, then you will probably need to replace timer.
Posted on Dec 12, 2008
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
I cannott get oven to turn on, asssume it is with the timer as light & grilll work. Model no 6381902
Light and grill work. I assume that the oven indicator wont light when you turn the oven on. If so the timer is probably in automatic mode. Set the timer to manual mode and the oven should work. If the indicator light is coming on at the moment the oven element is probably faulty.
Feb 11, 2011 | Ovens
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
I need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Feb 26, 2009 | Verona Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven wont work
Make sure your timer is set to manual and not auto.
Dec 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
New world 90TCgyro fan oven timer
From the New World Web site: "How do I set my timer/programmer into manual when it is set in auto? (5 & 6 button versions) On your timer there are two buttons, which read "cook time" and "ready time". If your timer is in automatic, you can return it to manual by pressing these two buttons simultaneously. REMEMBER - if your oven is in automatic it will not work until the time you set it to come on or if you return it to manual." Find more info on the link below: http://www.newworldappliances.co.uk/Common-Questions_p18.aspx
Jul 26, 2007 | New World 90TC Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
113 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
