Question about RCA P46924 46" Rear Projection Television
Turn tv on all it does is clicks but doesnt turn on
    Genius:
  • 1,199 Answers
This sounds like your flyback unit on your main board is burnt out! this is a commen problem and the part is in the 70.00 range!
This should fix ya!
Posted on Dec 12, 2008
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
Jul 14, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv just clicks doesnt turn on
The power supply regulator secton and fly back tansformer should be checked.
Apr 30, 2012 | Panasonic PV-20DF64 20 in. TV/DVD Combo
Click the power button, and makes clicks like trying to turn on, but doesnt. and keeps clicking. Sometimes turns on, sometimes doesnt. Anything i can do?
sounds like the bulb warning indicator is telling the tv that the bulb needs to be replaced.
you may need to replace the bulb but for now go into the service menu and reset the bulb .
Dec 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
My tv keeps clicking but never turns on sometimes it clicks then turns on and then i have to leave it on but then when i turn it off it doesnt turn back on and begins to click again
the power supply section of ur tv is not correct....
u have to change some capacitors in power supply section in circuit board in ur tv.
Mar 10, 2010 | Televison & Video
My tv will not turn on, it just clicks but doesnt
You will need to have the power supply board replaced. This is a common problem and Samsung has re-designed the new boards so this will not happen again. You can call 1-800-samsung for the nearest authorizd service center.
Feb 26, 2010 | Samsung LN-R409D 40 in. LCD Television
My tv doesnt turn on but it has a clicking sound
Hi, this clicking sound is coming from the power supply board. this Board accepts the power stream from the wall outlet and regulates it with capacitors and resistors and transformers etc.. when these components are malfunctioning or damaged, your unit will make these clicking noises.
Simply replacing the power supply board and fly back, if installed, will fix this issue.
Please rate and have a great day:)
May 18, 2009 | Televison & Video
Tv wont turn on, it only makes the click
well sounds like you have on h.v. or lost of b+ line also would first check for open solder connection or possible bad solder conn. first okay
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Tv doesnt turn/swith on
Without a Make or model it's hard to say, but I would have to say it's the IFT which is the High Voltage Transformer.
Jan 17, 2008 | Televison & Video
RCA P46924 46" Rear Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
