Question about Envision EFT920 (Black, Silver) 19 in.CRT Conventional Monitor
My Envision EFT920 monitor has black bars on side
My monitor, no matter the resolution or PC it is connected to, has black bars on the side of the display. The Monitor has the option to widen and shrink the screen, but even at it's max expanding, it leaves about 1/2 inch black bars on side.
Any help?
  • saojorge123 Dec 19, 2008
    Same problem but with Samsung 753dfx
  • 58 Answers
SOURCE: Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Posted on Nov 28, 2007
banar
  • 26 Answers
SOURCE: Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Posted on Jan 06, 2008
  • 67 Answers
SOURCE: screen shrinks
Possibility: Dust accumulated within.
Disconnect the monitor, and open it up. With a dry small paint brush and a vacuum cleaner, remove as much as possible. Especially around the tube and the ultor (the cable connected to the rear of the tube, usually has a rubber cup- like fitting on the tube end), then close up and test again.
Still doing it? This part requires great care, if you don't feel confident about working around a live chassis, DON'T!!!
Disconnect and open the monitor again. Connect up without its cover. Look around the chassis, you will see a number of adjustment potentiometers, possibly with markings such as "width" and "height" etc. Turn on the computer, and with a PLASTIC adjustment tool or TV alignment tool, (you can make one from a plastic knitting needle even), carefully MOVE each of these adjustments a bit, THEN RETURN THEM BACK TO THE POSITION THEY WERE IN.
Dirt often causes these controls to become intermittent in their wiper contact to the track.Moving them can restore a better contact.
There is also available fron electronic component suppliers, a pressure- pack contact cleaner product that can be sprayed onto/ into these controls, and may help if moving them does not.
If the above does not cure the problem, there is probably an electronic fault.
Remember, if you don't feel confident about poking around inside live equipment, DON'T, maybe you have a friend or relative who knows how.!!
Posted on Jan 19, 2008
SOURCE: Envision LCD EN-7100e Monitor "Input not supported
The problem was the resolution setup on the old crt monitor was not compatible with the new lcd monitor. I changed the resolution to one suggested/recommended by envision and the problem was solved.
Posted on Apr 24, 2008
leroyal
  • 2120 Answers
SOURCE: blinking screen on envision monitor
Burned out backlight fluorescent bulb.
Posted on Dec 26, 2008
The video adapters in win98se don't work for eft920
check the geometry for the monitor to see if it matches the video card.
Mar 05, 2014 | Envision Computers & Internet
Monitors
How to Fix the Resolution on Envision Computer MonitorsXll.jpg"> TS Jordan
TS Jordan is an Ohio licensed attorney living and practicing out of the Cleveland area. In addition to his Juris Doctorate, he holds a Bachelors' Degree in Information Systems. He has been writing professionally for less than a year.
By TS Jordan, eHow Contributor
Envision flat-screen computer monitors come with a "native" resolution, which is the resolution that exactly matches the number of pixels included on the monitor. Setting the resolution to the native standard will therefore produce the best image quality. You can utilize the display properties tools in your computer's operating system to fix your Envision monitor's resolution.
Read more: How to Fix the Resolution on Envision Computer Monitors ' eHow.com http://www.ehow.com/how_6666424_fix-resolution-envision-computer-monitors.html#ixzz2DLKKQZ4M
Nov 26, 2012 | Envision Computers & Internet
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
I have a Envision monitor EN7750 and now I get a black screen that say (input not supported).
Sir,
This happens when you have set a resolution that's not compatible to your Envision EN7750.Have u used the same monitor before with your Pc successfully? If you have just bought it and have got another monitor which worked with your Pc then connect that monitor monitor again and change your display resolution to 1280x1024 (its the default resolution supported by EN7750) and then connected back your Envision Monitor and it should work.
If you need assistance on how to change display resolution,then let me know.Hope it helped.
Oct 28, 2010 | Computers & Internet
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
I had envision 19'' but image is not too sharp
What is the model of this monitor? You need to find out the native resolution of this monitor, then set your PC video resolution to that numbers for best picture.
Apr 19, 2010 | Envision 19" Widescreen Flat Panel TFT LCD...
There's a colored bar that comes up on the screen that says "Out of Range" and the images on the screen are all fuzzy and wavy. The monitor is about 2.5 yrs old.
You need to set the PC video output to be at the monitor native resolution, look for the spec of your monitor to find what the resolution should be.
Envision model?
Mar 19, 2010 | Envision 19" Widescreen Flat Panel LCD...
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
if not worked
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Envision EFT920 (Black, Silver) 19 in.CRT Conventional Monitor Logo
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
