Question about Epson Perfection 3490 PHOTO Flatbed Scanner
Scanner won't work. It won't even turn on now.
  • Anonymous Oct 24, 2008
    it won't even turn on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Check connections. if they are fine, try opening the scanner box and see if the AC cable is not ripped (maybe you pulled it too hard). Let me know if this still doesn't work.
Posted on Mar 09, 2007
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Apr 17, 2013 | Brother DCP Office Equipment & Supplies
Scanner won,t pick up signals
you need to turn back the squelsh untill the scanner stops and you have to enter the frequencys manualy to get them you will have to go on googles and search for scanner frequencies
Feb 22, 2013 | Radio Shack Pro-95 Handheld Scanner
I convert scanner won't save document
1 on iPad gpt to Settings, 2 goto Privacy, 3 goto Photos, 4 turn on iConvert Scan
Jan 06, 2013 | Brookstone Office Equipment & Supplies
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
HELP! My HP Scanjet5470C worked PERFECTLY - not anymore
u'r scanner have to turn on first for the computer regocnize
try another power outlet, if the scanner turned on, it means the power outlet u used now is poor...
u can check the power adapter first
Mar 12, 2009 | HP Scanjet 5470c Flatbed Scanner
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Perfection 3490 PHOTO Flatbed Scanner Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
