Question about LG Shine KE970 Cellular Phone
Lg shine acting werid.
My lg shine is acting really weird. When i look at the screen its really dark and i already adjusted the contrast but anyways the screen images are really dark and on the menu you can't even see the lines that are dividing all of the topics. whether its messages, address book, settings. So thats my first problem.
Then also. My phone is freezing up on me a lot! and i can't scroll down. So i have to keep shutting it off. One thing i do know is that my phone has water damage. Because on my battery there is a red dot. So i know that there is water damage for sure. But i don't know if that is why my phone is having all of these problems. Please help me i don't know what to do next.
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
I have an LG tv about 5 yrs old and suddenly the screen is darker and I have adjusted it to 90 percent bright / contrast etc and still dark ...
one of the components
chip or circuit board has failed
if you cant source that part
time for a replacement
Oct 30, 2016 | LG Televison & Video
We recently got a new LG 42" 1080p HDTV and occasionally the screen goes dim/gets slightly darker while we are watching shows. It is not the show as I have tested the same spot the dimness occurs...
It can be the auto-contrast is doing its jobs so LG can claim that the TV has really high contrast ratio, also try turning off auto brightness feature off. It gets real bad when the scene has dark back ground such as the dark sky with stars, the TV will really dim down to give real black sky but at the same time you can barely see the stars on the screen, LG is not the only one with this design problem, VIZIO and other has the same problem as well. If you Google your model and search for review you may see that you are not the only one with this problem.
What is the exact model of this TV.
Please let me know what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Mar 09, 2011 | LG 42 in. Flat Panel LCD HDTV
No display in my lg shine cu720
What happened in the first place to make your lcd screen go out? there is a chance that the problem was not the screen, but the phone it self. did you drop it in water, or jus cracked screen?
Jun 10, 2009 | AT&T LG CU720 Cell Phone - Silver
Lg 50px5d tv have sound no picture
check inverter. adjust brightness and contrast.
May 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
LG Shine screen display
replaced the LCDS on the phone
Aug 19, 2008 | LG KG800 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Lg shine tu720
How come whenever i import songs for my TU720 using the LG software it came with, it gets saved to the Rogers music player instead of the music player that is already built in the phone ? ( this is usiing the internal memory )
Dec 20, 2007 | LG Shine KE970 Cellular Phone
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
LG 77m monitor
Is the problem on all signal to display? If any signal is dark, the inverter is going bad.
Mar 28, 2007 | LG Studioworks 77M Monitor
LG Shine KE970 Cellular Phone Logo
108 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
