Question about Sony ST-SA50ES 2 Channels Tuner
How to program pre-sets on a Sony tuner ST-S100L
Can you tell me how I set the pre-sets on my Sony ST-S100L?
  • Anonymous Mar 19, 2014
    stereo
  • Anonymous Apr 01, 2014
    I programmed my new (second hand) ST-S100L yesterday evening with 18 stations succesfully, this morning they were all gone! There was no powerfailure.
    What I found strange that to get the station back (yesterday) you had to press enter after choosing the 1, 2 or whatever.
    Thank you.
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Posted on Dec 28, 2008
Need codes to program for a va-405 5 in 1 remote for a sony tuner model number st-jx380
0131 0154 0177 0211 0301 0302 0357 0358 0609 0785. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 25, 2014 | Universal Remote Control Remote Control
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
Sony VGC LT16E VAIO live tv tuner hardware cannot be found
Go to "Device Manager" and look for anything that has a yellow question mark. If you see this, you need to run the set up program for that device to install the driver/.inf file and let the setup program set other parameters.
Since you reformatted, you removed all your previous settings unless you backed those up previously. If it came with the laptop from the store, it should have come with a CD or DVD rom with the install program.
If you lost that, or cannot find it, go to the Sony website, select "support" and locate that driver or set up program and download it. Make an archive copy of it in case it is needed in the future. The device manager should identify what model of tuner card you have.
Dec 10, 2011 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Is there an internal battery on the STR-DE345 Sony receiver for the pre-sets? Can it be replaced if there is. Receiver no longer holds pre-sets when there is a power outage.
There is no battery to replace to hold preset channels. The preset channels are held by a charged capacitor to maintain the nominal voltage level to the PLL (phase lock loop) tuner. The capacitor can only hold the charge for a few hours, and then it will slowly discharge - for like a short power outage.
Dec 24, 2010 | Sony STR-DE345 Receiver
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Pre-set sony s300 tuner
Do you have instruction manual of DAV-S300 to get to know about tuner presets?
Jun 13, 2009 | Sony DAV-S300 System
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
I have lost my paperwork and forgot how to program my remote
Turn the device on that you want to program. Press and hold  Set for 2 seconds.  When the light is on, press the device button you want to set.  Then press the Channel + or - and press power after.  When the device turns off, press enter and your code is saved.  If all functions do not work after this, repeat the process until you get the right one.
Nov 22, 2008 | Sony RMV210 Remote Control
Magnavox 15MF400T/37 Channel chosen is not correct channel
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Mar 25, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Sony ST-SA50ES 2 Channels Tuner Logo
1,366 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
