Question about Philips VR550 VHS VCR
Playback sound I have recently purchased the Philips VR 550 VCR and when playing tapes there is a background interference noise that sounds like a helicopters propellors whiring round. At first I thought it was because I was playing tapes I had recorded on another VCR but it also happens with programmes recorded on the same VCR and with pre-recorded tapes. The strange thing is that this noise goes away if you move closer to the VCR or hover your hand over the VCR and its gets louder as you walk away.
  • Anonymous Mar 07, 2008
    i've also just bought this unit, and I have the bagground inteference too! I suspect it's got something to do with tape tracking. I've noticed that when you use the tracking buttons (channel up and down when in play mode), the noise will disapear, but you'll now be playing your tape with mono-sound in sted of stereo.
    I am most frustrated, and I wanted to hear if you've found a solution to the problem?
    All the best from Allan
    Denmark
    Novelist:
    Champion:
  • 254 Answers
Unit might be picking up 60 cycle hum or other electromagnetic field. Is VCR sitting on/under another piece of electronic equipment? If so, it could pick up such from the power supply circuitry of that other device. Try moving the VCR away from other equipment and see if the unwanted sound disappears.
Posted on Mar 12, 2007
I Need a Manual for a philips VR 550 Video wilson@theyealm .co.uk
You have not mentioned which version of VR 550 user manual you need but the following pages at nodevice.com give you free dowloads for your manual: you will need to copy and paste these links into your URL window in internet explorer.
http://www.nodevice.com/user_manual/philips/vcr/vr55002/download.html
http://www.nodevice.com/user_manual/philips/vcr/vr55007/download.html
http://www.nodevice.com/user_manual/philips/vcr/vr55016/download.html
You have to enter the verification code at the bottom of the page correctly before you can access your manual
Oct 05, 2009 | Televison & Video
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No sound Problem - Philips VR550 VHS VCR
If your pre-recorded tapes also play without sound, then check the scart lead is in straight.
If not, then it's more likely to be a dirty audio head.
Try a VHS head cleaner tape.
May 20, 2008 | Philips VR550 VHS VCR
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Philips VR550 VHS VCR Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
