Question about Garden
Recoil starter wont turn
I think you replied to this one, The pulley only goes out a little ways, and it seems the motor is seized.
  • Anonymous Dec 24, 2008
    Same thing. I may have stepped on the bottom cover just above the tines so I could pull better but I have the same thing. I can't pull the recoil at all
    and just seems locked.
  • 76 Answers
Try taking the recoil cover off and with a pry bar or a big flat head screwdriver positioned in the flywheel, remove the spark plug and try to rotate the flywheel. Don't pry to hard so you dont snap fins off. If the fly wheel does rotate the the problem is the recoil, if it does not rotate then you will need to get a can of Deep Creep Seafoam from the auto parts store and spray the seafoam into the spark plug hole, while spraying it into the spark plug hole try to coat the cylinder wall with it (don't spray to much, just enough to coat the cylinder wall and just cover the top of the cylinder) let sit over night then spray it again the next day,then try to rotate the flywheel again. If it still don't rotate then you will have to pull the head off and you will have to get someone to help with this part, while one person tries to rotate the flywheel the other will have to take a hammer useing the end of the handle while holding the head of the hammer and hit on the top of the piston to force the piston free, you can also use a deadblow hammer and hit the piston with the head of the deadblow. Also if the piston is not at the top of the cylinder you want to rotate the flywheel backwards (counter clockwise).
Posted on Dec 28, 2008
Recoil starter pulley not retracting starter string. How do I replace it?
there is a spring that recoils the rope inside .not a hard task but rather tricky with the spring .good luck
Sep 09, 2016 | Garden
How do I get the cord to pullout to start? It won't come out.
remove the recoil starter assembly and see if you can turn the motor by hand
if yes then check the recoil starter
if no then service the motor as it is probably seized up.
May 25, 2015 | Garden
You will need to take the recoil starter apart and inspect. The pull cord may have to be replaced.
Apr 21, 2015 | Garden
2005 santa fe serpentine broke then bad vibrating and it died replaced serpentine and tensionor, now motor locked. Is the motor shot or could something else be wrong?
Put a socket and wrench on the crankshaft pulley bolt, and see if you can turn the crankshaft-clockwise. If the crank won't turn, something internal is bad. If you can turn the crankshaft normally, check that another pulley has seized.
Or try it this way: take the serpentine belt back off and see if the starter can spin the crankshaft. If it does, look for a seized pulley. If a good battery cannot make the starter turn the crankshaft, likely the motor is shot.
Aug 15, 2014 | 2005 Hyundai Santa Fe GLS
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Apr 17, 2013 | Stihl Concrete Cutoff Saw Rewind Recoil...
Lawn mover starter rope replacement
most starters can be taken off the engine and replace the rope without completely tearing the whole unit apart. by that I mean you should not have to mess with the recoil spring unless it is broken. remove old rope from pulley, wind up the pulley and hold it so it wont unwind, replace new rope onto pulley and tie a good knot and melt the ends of the rope so it wont unravel, then slowly let the pulley retract the correct amount of rope. if the recoil spring has unsprung on you, it will take a little time and probably several tries to wind it back up and position it back in the starter. they like to unspring while doing this so take some time and an extra person to hold and assist might go a long ways. good luck. R
Aug 25, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
Pull start on my Toro snowthrower (snow master 20 - model #38020) it wont recoil itself. I removed the starter housing but can not figure out how to get the pulley and starter recoil spring out/off of the...
Its basically the bet is to just buy the new pull start mechanism...they are pretty cheap, and they go bad on those units all the time.
Jan 12, 2010 | Toro Garden
Drove from home to gas station, filled up started out of station
try taking plugs out and turn it over if its turning over then you have a injector leaking im assuming it wont turn at all even with a wrench
Aug 15, 2009 | 1999 Suzuki Grand Vitara
I ran my car thru water about 2 weeks ago and it died on me then but i chack and theres no water in the motor but it wont start now the starter jus clicks and the inside lights just go dim
You need to check the connections at the battery. They could be corroded causing your battery not to produce enough juice to turn the engine over. Have the battery checked as well
RPM Northwest
Jun 12, 2009 | 1996 Plymouth Neon
Garden Logo
413 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
