Question about Indesit W 123 Front Load Washer
Indesit 123 not rotating
It turns on but it doesn't rotate inside
  • Barry Coates
    Barry Coates May 11, 2010
    What does happen when you turn on, anything?
Mine did this today, but we fixed it. Just the belt had come off.
Disconnect from electric.
Remove back panel by removing 5 or 6 screws with a screwdriver.
Put belt back on.
Screw back panel on to machine again.
Sorted !
Posted on Dec 14, 2008
Washer fills water, drum is stuck
you may have a sock stuck in between the drums
rotate the drum when it becomes stiff you stop then take out the lower paddle by pulling it
you may now see the sock
Dec 01, 2013 | Indesit W 123 Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Clinking noise
after the load is done look in the unit it and hand spin the drum slowly It sounds like you have a coin or something stuck in the baffles rotate untill you can pin point it..
Jan 27, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer
check heater element first, thats a common fault on these machines, loose connection or open circuit, after that check the pump for same open circuit
the rotating of the timer knob indicates a fault, maybe even a setting fault, to try and reset set to off, turn off and back on again, till light flashes, then turn off again and start again
if you do not know how to test for open circuit then the job is not for you, sorry
Oct 14, 2007 | Indesit W 123 Front Load Washer
Indesit wg 1285w
Replacing the capacitor might solve your problem. Good luck!
Aug 30, 2007 | Indesit W 123 Front Load Washer
W123 Wont rotate
some indesit washer have a module if you pull your washer out make sure power is off take the back off and you will see it on your left hand side it should be in a plastic cover with about 8 wires going into the cover there should be 2 screws that locate this to the back of your washer if not then it will have carbon brushes if these are lower thanabout 8ml long they need replacing these are locatable in the motor by having 1 small wire going onto them they will be plastic with the carbon inside pf them m8
Aug 12, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
169 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
