Question about Microsoft Xbox 360 Console
Xbox 360 3 red lights can anyone please help?
  • coeyfranklin May 11, 2010
    the hard drive is knackered
    Scholar:
  • 31 Answers
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Mar 06, 2009
  • 63 Answers
That has absolutely nothing to do with the Hard drive. The red ring of death is a standard misfunction with the Xbox 360. You will have to contact your local game stores to see if they do Red ring of death fixes, send it in to microsoft, or attempt to red ring fix it yourself.
Posted on Dec 13, 2008
3 Suggested Answers
  • 29 Answers
SOURCE: xbox 360 1 red light
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red light Error) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Posted on Mar 14, 2009
  • 12 Answers
SOURCE: As playing Xbox 360 system shuts off two red lights occurs.
2 red lights is overheating you can try and leave the console alone and see if that cools it down, sometimes this will work.If it does not you will need to get it fixed and to do this you should use a good Xbox 360 Repair guide or send it in.
Posted on Nov 05, 2011
Red light come on xbox360 what is the problem
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 13, 2010 | Video Game Consoles & Games
Xbox 360 wireless adapter 1 red flash of light
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
Jun 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 q1 and q2 lights going red
i dont now because my xbox 360 do the same thang
Apr 21, 2010 | Microsoft Xbox 360 Console
I play for +- 30 min and the powersupply goes on red is it the powersupply or the box
If you are getting a red light on the Xbox 360 power brick, That happens when the power supply gets to hot or its not getting enough juice. Try plugging it in somewhere else and see if that helps, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter
also check if the power connector is firmly connected or not behind your xbox 360, if you still have a problem, check if you can borrow another Xbox 360 from anyone you know and swap the adapter and console which would help you know where the problem is
If none of this works, call up Microsoft for further help and support, since your problem may require servicing of your console.
If you are getting a Red Ring of light on the Xbox 360 power button, please clarify since it requires separate diagnostics.
Hope you get back to gaming on your Xbox 360 ASAP
Dec 01, 2009 | Microsoft Xbox 360 Console
2 RED LIGHTS
Here is a website I used when my 360 went haywire. It helped me out, maybe it will help you or at least lead you toward the right direction.
http://forums.xbox-scene.com/index.php?showtopic=484726
Aug 03, 2009 | Microsoft Xbox 360™ Premium White Console
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
Jun 15, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 2 red lights
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Apr 21, 2009 | Microsoft Xbox 360 Console
Xbox freezing constantly
You can check out the articleatezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369formoreinformation on fixing freezing problem of your xbox 360
Jan 01, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
3 red lights
red light of death. Try turrning it off let it sits for a while then turn it back on if it still does that then the xbox is dead. unfortunatley this is a common problem with xbox 360 MS has extended the warranty on these and there's plenty of articles out there on these xbox.
call them and get them to fix it or replace the machine for you.
sorry i don't think anyone can help you.
good luck
smeags
Dec 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
113 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
