Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202 how do i adjust the color i tried from the front ,but did not work .then i tried the back still the tv seems to have a haze how do i fix it
    Scholar:
  • 87 Answers
You have contaminated coolant fluid in the blue and green picture tubes.I do not reccomend that you attempt this repair.A shop should be able to get this unit looking like new again for about $275.
Posted on Jan 12, 2009
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
I have a Philips projection screen hd tv great picture but the color is way out off adjustment
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
SD TECH
Oct 30, 2011 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202/17F rear projection TV. its getting worn. The overall picture seems to have a slight haze and also seems to have lost the color contrast. yellows and whites are very similar and...
Thats most likely a CRT coolant issue where you will need to remove and replace the coolant in the CRTs ( picture Tunes) Thats a very common problem with Phillips rear projection. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for a 3 CRTs and the CD with instructions.
Jul 22, 2011 | Philips Televison & Video
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
Adjusting the color
replace the coolant in the CRts. You can get the Phillips CRT coolant kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hi i have a phillips 43pp6360/79 it has a very cloudy over bright picture. Also when adjusting the blue convergence the second cross dosent appear anywhere but a slight blue haze moves around the first...
I'm not quite sure about the convergence issue, but the glowing white haze is a sign that the fluid in the color tubes is dirty and usually can only be fixed if the fluids are changed out(draining and refilling). This is not recommended for someone who does not know what they are doing, it is best to get an expert to do this work because it can be dangerous as well as hazardous to your television and quite expensive. Mostly all rear projection televisions will have this issue, but I find that just upgrading to a newer-model television is usually better, maybe a flat panel LCD(Liquid Crystal Display)(stay away from unknown brands and plasmas, although Vizio's LCDs will get you more bang for your buck). On an LCD, all you really have to worry about is cracking the liquid-crystal display, which is quite fragile, but can be avoided if no hands or objects touch the LCD. On the other hand, best of luck in fixing your Philips rear-projection.
May 16, 2009 | Philips 60PP9202 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202/17F Blue Problem
call the repairman back and tell him the tv isnt fixed correcctly. have him come back and finish the work he started
Jan 27, 2009 | Philips 60PP9202 60" Rear Projection...
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 43PP6360/79
if the hase your refering to a glowing halo its the blue coolant that needs changing. If it causing a 3D image then its the convergence ICs need changing
Mar 23, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
